Primer for brass
- KNO3
Primer for brass
Hi all,
I was wondering what is a good primer for applying to brass before painting?
I use Precision Paints etch primer, which comes in a spray can. Dom't know whether you'll get that where you are, or whether Precision Paints will ship it to you.
http://www.phoenix-paints.co.uk/precisi ... mer-1.html
- Snailrail
- Keith S
If you go to any store that sells automobile paints, you should be able to find a can of "self etching primer". If you read what it says on the label, if it is the correct stuff it will say that it is for non-ferrous metals.
If you are REALLY stuck and can't find any, you can do a pretty good job on brass by giving it a thorough cleaning with a strong degreaser (NOT washing-up liquid!!!) and then putting the piece you wish to paint in a bath of diluted (1/1) muriatic acid (available from swimming-pool-supply stores) for an hour or so to gently "etch" the brass. Rinse with water and then spray with regular metal primer.
This is what I did with my Roundhouse engine body- and the paint stuck to it very well. I later found some self-etching primer when I built a new cab for the engine, and I don't think it worked any better than the above method... it was just a bit easier.
By the way when you are done with it, it is very easy to make muriatic acid disappear... just pour sodium bicarbonate into it until it stops bubbling... you're left with harmless brine.
Busted Bricks
- rebelego
