![Image](http://s20.postimg.org/lsfxgvfct/IMG_20150802_132522_s.jpg)
There are two issues that need sorting out:
I made a design boo-boo with the water gauge, it is tapped off the same boiler bush that feeds the regulator. This results in boiler water being pumped into the motor. It ran quite nicely, though the exhaust was rather wet, and the huge boiler was drained in around 5 minutes! So I quickly removed the water gauge. I now wish to re-instate it.
The displacement lubricator doesn't work on it's own, and requires an auxiliary steam feed (lower hand wheel on the lubricator).
![Image](http://s20.postimg.org/xituy9859/20150530_184519_z.jpg)
Best wishes,
Dave.
