slip eccentric
JMORG
slip eccentric
Post by JMORG » Sun Mar 08, 2015 8:34 am
Hi guys!
As some are aware, I am building a model of Moel Tryfan. It's temporarily on hiatus due to my old man making 2 Garratt locomotives (similar to the Rachel tiny Garratt), but will restart afterwards.
After looking at the Roundhouse valve chests, I have concluded that new valve chests will be made (based on wild rose).
The slip eccentrics are causing sleepless nights due to the relative complexity. I have an excellent book buy Mark Horovitz describing loco building and he mentioned castings for the eccentric straps.
Does anyone know of a company that might do these castings? :)
Apart from that, small details have been made (chimney, Salter safety valve, air reciever ect) along with the wheels and the rear bogie. Work on the frames is the current job!
DVT Dweller
Post by DVT Dweller » Sun Mar 08, 2015 7:42 pm
Could you not get the straps laser cut from steel instead of casting?
kandnwlr
Post by kandnwlr » Mon Mar 09, 2015 8:05 am
DVT Dweller:108893 wrote:Could you not get the straps laser cut from steel instead of casting?
You might talk to Stewart Browne of Archangel, who is an expert on slip eccentric mechanisms, and has been doing this stuff for ever.
Post by Big Jim » Mon Mar 09, 2015 9:32 am
Have a look at Dave Watkins live steam site.
http://www.davewatkins.pwp.blueyonder.c ... /steam.htm
There are some plans for Wild Rose and a links to a blog about how he is building it. Including some bits about slip eccentrics.
Re: slip eccentric
Post by GTB » Mon Mar 09, 2015 2:42 pm
JMORG:108878 wrote: Does anyone know of a company that might do these castings?
Castings for slip eccentric straps were commonly used in the past for Gauge 1 locos., such as those designed by LBSC. Peter Jones has photos of them in his steam loco book.
Model engineering suppliers like GLR Kennions, Reeves(2000), etc. would have supplied them in the past and possibly still have suitable G1 castings.
They aren't particularly difficult to fabricate though. The Wild Rose 111 design previously mentioned is a simple design. Castings are usually pretty crude and by the time you finish setting them up and machining them, it's almost as much work as machining a set out of a piece of suitable size flat bar.
See Dave's page at http://wildrose16mm.blogspot.com.au/201 ... traps.html
The reprint of Brian Wilson's book is due out soon and he has a design in there for a slip eccentric valve gear that is easily fabricated.
I think the G1MRA Project design also uses fabricated eccentric straps and might be worth a look. Someone may do castings, as a lot have been built.
LnBmad
Post by LnBmad » Mon Mar 09, 2015 2:55 pm
cannot recommend 'model steam locomotives - by henry greenly' enough if your trying to understand how to make valvegear of any description.
the machining of slip eccentrics isnt hugely complicated, the designing just takes a bit of thought is all.
JMORG
Post by JMORG » Mon Mar 09, 2015 5:28 pm
Thanks everyone! :)
It's all good suggestions and food for thought.
I promise to post pictures once work restarts
