UK Rolling Stock in G - Project not yet started
Automatic Lights At Night
Installed a dusk / dawn sensor on the outside of the garage, this is then connected to a DS64 input (via a relay) so TrainController on the PC knows if it is dark outside and turns the loco lights, carraige lights and tail lights on when trains leave the garage.
Test it with a black bag to simulate darkness and all working.
OTT Carraige Lights
Using LED strips inside two coaches and a couple of spare decoders i had...
We now have a choice of blue, white or combined lighting + the rear coach has a red tail light and the other one has separate lights in the toilet compartment.
Re: UK Rolling Stock in G - Project not yet started
Back area trackwork in progress, just the block wiring left to connect.
Half way through Half way through Finished track ready to be fixed in place
That is going to be a busy railway when it is finished Steve.
Should be able to have 5-6 trains running under automation at once, will probably be more like 3 moving and the others stopping in station and waiting in passing loops etc.tom_tom_go wrote: ↑Sat Apr 08, 2017 9:06 pm That is going to be a busy railway when it is finished Steve.
How are you programming the locos for automation? Will they run in a block system with sensors or shuttle mode?
looking great looks like your very good at electrics keep it up and keep us all posted
one thing the light sensor you have used iv seen used before and the plastic on the top tends to fade and make the sensor not work .
Its DCC (or MTS as LGB call it)tom_tom_go wrote: ↑Mon Apr 10, 2017 9:12 pm How are you programming the locos for automation? Will they run in a block system with sensors or shuttle mode?
Its a block system using TrainController Gold from Freiwald with Digitrax hardware.
BDL168's for occupancy detection.
DS64's to control the solenoid valves which in turn allow air to control the points.
I'll keep an eye on that, it was just a £15 job so i wasn't expecting much at all!
On with the 'scenery' - this arrived full this morning
Will possibly do a top cover of smaller size slate chippings (20mm i used everywhere else, these are 40mm as that's all the patio center had in a dumpy bag) Next step is some of that plastic fake grass to go round the vegetable patches
Then got spread out to fill in the back area, piled up high at present as from past experience it settles quite a bit.Will possibly do a top cover of smaller size slate chippings (20mm i used everywhere else, these are 40mm as that's all the patio center had in a dumpy bag) Next step is some of that plastic fake grass to go round the vegetable patches
I was going to sell off some auto carriers as they are the incorrect scale (full size and I've only got narrow gauge RHB stock) but turns out that with some chopped up broom handles and bamboo canes they look ok as some logging cars.
https://youtu.be/XtWvDt6k-0E
Progress has begun on landscaping / walls on the back return loop area.
Getting there Steve, looks promising...
Looking good nice bit of brickwork
and the soil is in...
What is the bricked smaller cylinder for on the right?
Fire pit... yes it has been tested with the biggest fire possible and plastic tubes sticking up from track level behind it so it shouldn't melt the trains!
Trains and a camp fire, brilliant...
