IP Engineering L&B Coaches
SpudUk
Post by SpudUk » Mon Feb 02, 2015 11:38 am
Anyone built the IP Engineering L&B coaches, the taller ones designed to fit with Accucraft locos? Considering getting two of the 3 compartment coaches and wondered if anyone had fitted duckets to them?
Chris Auckland
maxi-model
Post by maxi-model » Mon Feb 02, 2015 1:04 pm
I have built one of their other kits with a ducket. It was a fairly simple procedure. Just a bit of thin ply with some ends and a bit of hot water. Stained then superglued together. Surface mounted to the body. Easy to fabricate oneself.
Or you could get the vac formed add on plastic items from the GRS range. They come from the L&B kits. Max.
