paint lifting on buildings
I have several buildings from Modeltown and British Outline Buildings. All were thoroughly washed with washing up liquid, primed with Halfords primer and then painted with either Pheonix precision paints or Humbrol enamel. After a year or so outside (and it wasn't a harsh winter) the paint is peeling and lifting. I am at a loss about how to prevent this. And also how to mend it. I have tried rubbing off the offending paint and repainting but within a few weeks it peels again. Should I strip the old paint off (and with what) and repaint, or does anyone know a better solution? Many thanks.
I used plastic bumper primer, a car product. Semi matt paints last longer than matt as matt get washed away slightly. I reckon 3 years and its time for a quick touch up. I did hear of a guy who used exterior masonry paints but I have no experience of this at all so I'm not sure. Sunlight and frost are the enemy. I'm still on Humbrol like I say with an spay car plastic primer underneath.
I have several Modeltown buildings on my line. The first ones weren't even primed just washed and painted. I used Revell Aqua Color paints, they seem to stick very well to the resin that Modeltown use. The first buildings i did have been outside now for 2 years and the paint is still ok. These days i still use Revell Aqua Color but prime first with Halfords Plastic Primer.
- andymctractor
Using washing up liquid or other kitchen cleaner can leave residue on your model. This stuff keeps your hands soft but doesn't help paint to stick. Use decorator's soft soap or similar. I get mine from B+Q it's a yellow liquid.
As these are chunky resin kits you can use an etch primer but make sure all the wash water has dried up and make sure you leave the primer at least 24 hours.
This may not be the answer for your problem but it works for me.
Good luck
Good luck
Andy McMahon
Andy McMahon
