Quarry Hunslet in 7/8 ths scale
Hi and welcome.
The answer to your question really depends on the thorny old question of scale/gauge combination. Building it to run on 45mm doesn't necessarily mean that you have to scale the loco up if you don't want to but if you do, that means you will of course need everything else ( wagons, buildings, etc) scaled up by the same amount.
- GTB
Re: wild rose in 45mm
There's no 'correct' approach, it's your railway.....qh45:103669 wrote: My initial thoughts are to use the 32 mm drawings and to multiply dimensions by 1.4 to get to 45 mm gauge dimensions, and just wondered if this was the correct approach.
Multiplying all the dimensions by 1.4 will give you a 7/8" scale Quarry Hunslet, if that's what you want.
If you want an SM45 Hunslet, which is basically a 2'6" gauge one, then you just need to make it wider below the footplate. Add 13mm to axles, chassis spacers, etc. and maybe make the footplate and cab wider. There'd be no need to modify the smokebox, boiler, tank and fittings dimensions in this case. Cylinders and valve gear would remain the same as well.
I don't know if Hunslet ever built a 2'6" gauge QH, but there was one built for 3'6" with inside frames and cylinders.
DLRdan
DLRdan
Alan P
- paullad1984
http://www.thetraindepartment.com/coal- ... comotives/
Looks interesting!
Looks interesting!
