Plastic guttering for buildings?
- Mrs F Controller
I know a couple of years or so ago, I got a pack of grey 'guttering and down pipes' for my lineside cottage etc. They were on a snap off framework where you selected length, bend etc and just snapped off the ones you required. For the life of me I can't remember where I got them from! Any ideas? I've been googling away and looked at various websites but can't find any! Help!
- Mrs F Controller
Yes, I have used those black plastic ones for down pipes but I find that splitting them for the guttering itself fiddly and not very satisfactory! I did really like the ones I used before because they were shaped like gutters etc and thought it would be good to use again but don't think it's going to happen!
- andymctractor
I have some 'plastic' modelling strips that are the correct shape for guttering. It is a little overscale in thickness. I got it from Hobbies of Raveningham. They have a website but I had to wait for them to order this in special.
If you could make do with solid half dowelling then that is easier to find suitable material for. Or go for the square crossection guttering and look at Plastruct.
Would you let us know if you find a supplier for the stuff you've used before?
Andy McMahon
Andy McMahon
Speaking as a man who agonizes over different guttering techniques, I will be posting some pics as the mood takes me. Seriously though, Piko does provide some stuff which would help. In the meantime, try "dollhouse heaven".
- andymctractor
I've not used them myself, but have you thought about the products listed under 'Building Parts' on
www.trenarrenmodels.co.uk ?
Andy McMahon
Andy McMahon
- Mrs F Controller
Thanks for all the replies guys! Yes have looked and Trenarren but they are white metal so no good hate the stuff! Have thought of dowel yes and still is a possible but still looking. I believe that the bag of guttering we did get came in a box of mixed bits we purchased from eBay a few years ago so probably no longer available. Will keep the search up!
I was down in the cellar and found a bag or two of what I bought "in bulk" a while back. The label says Faller, the German G scale buildings company, and comprises of both plastic guttering and drainpipes. Hope this helps.Mrs F Controller:99733 wrote:Thanks for all the replies guys! Yes have looked and Trenarren but they are white metal so no good hate the stuff! Have thought of dowel yes and still is a possible but still looking. I believe that the bag of guttering we did get came in a box of mixed bits we purchased from eBay a few years ago so probably no longer available. Will keep the search up!
[quote=
I was down in the cellar and found a bag or two of what I bought "in bulk" a while back. The label says Faller, the German G scale buildings company, and comprises of both plastic guttering and drainpipes. Hope this helps.[/quote]
Please take great care when ordering Faller modelling bits and pieces. Faller are certainly not a G-Scale modelling company. A great deal of their kit is both N-Gauge and HO and is often not always marked up clearly as such.
Cheers
Roy H
Roy H
Enginehouse:99743 wrote:Good point. Faller is the parent company, Pola, formally independent, is the brand under which the G scale stuff is sold (all other scales are marketed as Faller). But apparently everything gets packed in Faller bags, even if it came in a Pola box. A quick look at the website will show two packs, 333114 and 333115, labelled as gutters, which I use when building my stuff. Have fun.I was down in the cellar and found a bag or two of what I bought "in bulk" a while back. The label says Faller, the German G scale buildings company, and comprises of both plastic guttering and drainpipes. Hope this helps.[/quote wrote:
I bought a 3m length of cable conduit from wickes. Its oval section, about 25mm by 8mm. Then it's just a case of cutting off the oval bid each end and hence guttering. Can post pics if required.
This is the stuff http://www.wickes.co.uk/Oval-Conduit/p/109641
Nice ideaikcdab:99785 wrote:I bought a 3m length of cable conduit from wickes. Its oval section, about 25mm by 8mm. Then it's just a case of cutting off the oval bid each end and hence guttering. Can post pics if required.
- Mrs F Controller
Well, kandnwlr I could kiss you!! yes yes yes the Pola 333114 are THE EXACT ONES! Thank you and I have managed to locate some and they are winging their way to me. Yes I know they are slightly small and short but that can be sorted and they look good.
I liked the conduit idea but wasn't really what I was looking for. I have used ballpoint pens, straws work well but I was after what I had in particular.
Thank all of you for you replies. I've got some great ideas and I would love to see some of your photos and I will put up mine when I've finished!
That´s what all the girls say 8) In the meantime, check out the Kent & North Wales Light Railway thread for a feeling of what can be done with some of the stuff. As Oscar Wilde once said, "All of us are lying in the gutter, but some of us are looking up at the stars." Not that that helps when, as tonight, I once again glued myself to my own scenery.Mrs F Controller:99876 wrote:Well, kandnwlr I could kiss you!! :hello1: yes yes yes the Pola 333114 are THE EXACT ONES! Thank you and I have managed to locate some and they are winging their way to me. Yes I know they are slightly small and short but that can be sorted and they look good.
Would it be possible to give the dimensions of this guttering please.Mrs F Controller:99876 wrote:Well, kandnwlr I could kiss you!! :hello1: yes yes yes the Pola 333114 are THE EXACT ONES! Thank you and I have managed to locate some and they are winging their way to me. Yes I know they are slightly small and short but that can be sorted and they look good.
Reg
Here are some pics of building work on the K&NWLR to give you a feeling for the length of the pieces supplied that I had available in the Faller box. Apologies if the Treddol slate station looks as though it´s on a building site .... but it is.nzreg:100273 wrote:Would it be possible to give the dimensions of this guttering please.Mrs F Controller:99876 wrote:Well, kandnwlr I could kiss you!! :hello1: yes yes yes the Pola 333114 are THE EXACT ONES! Thank you and I have managed to locate some and they are winging their way to me. Yes I know they are slightly small and short but that can be sorted and they look good.
K&NWLR: Treddol-built station in slate with Faller guttering prior to completion by kandnwlr, on Flickr
K&NWLR: Treddol-built slate station building with Faller guttering to illustrate length of kit pieces by kandnwlr, on Flickr
K&NWLR: Faller guttering shown next to upper loop terminus station for scale purposes by kandnwlr, on Flickr
