Auto drain cocks
LnBmad
Auto drain cocks
With the fox being a fair few years old, she likes to spit out a lot of oil and water when she first starts. Am I correct in thinking that by fitting a set of auto drain cocks the oil and water will be drained and therefore not be spat out of the chimney? I know how they work on a larger scale but haven't got my head around how they work in 16mm
- Keith S
I'm intrigued by them myself, but haven't looked into it because Roundhouse engines have rather low-slung cylinders, without much room under them, and also because I would be nervous drilling and tapping holes in my locomotive's cylinders. Apparently they work quite well, although I can't figure out how the "auto" part works.
LnBmad
- Keith S
I suppose you're right about the spring, it's just that I have trouble understanding why the pressure in the cylinders is high enough to overcome the spring when there is water in them, but not when there is only steam. I mean all the pressure originates in the boiler, and you can't compress water, only steam, so how is the pressure on the spring made higher by the water being present? You must be correct, it's just that I can't picture it. I should have paid more attention in school maybe.
DLRdan
The auto part is very simple. There is no spring just a ball, loose in the housing. The when the cylinders have no pressure in them the ball falls off its seat alowing the water or steam out the drain. When the pressure is increased the ball is blown back onto its seat, stopping the steam coming out. They work in large scale as it takes a lot of steam to blow the ball back onto its seat but in smaller scales the ball is much lighter so is easily blown back into the seat.
LnBmad
Now that's exactly the sort of answer I was after! So if I fitted a set of these to the fox I should get all the water and crap out through the draincocks and get some clean pulling away?DLRdan:92224 wrote:The auto part is very simple. There is no spring just a ball, loose in the housing. The when the cylinders have no pressure in them the ball falls off its seat alowing the water or steam out the drain. When the pressure is increased the ball is blown back onto its seat, stopping the steam coming out. They work in large scale as it takes a lot of steam to blow the ball back onto its seat but in smaller scales the ball is much lighter so is easily blown back into the seat.
DLRdan
From the ones ive seen fitted with the drains they dont work very well, they seem to shut almost instantly and then the water still gets thrown out the chimney. After a quick search i came acros this video. As can be seen, only a couple of drops come from the drain cocks, the rest is being forced out the cylinder ends and dwon the chimney.
<object width="560" height="315"><param name="movie" value="//www.youtube.com/v/r_u-Sy8rn8Q?hl=en_GB& ... ram><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="//www.youtube.com/v/r_u-Sy8rn8Q?hl=en_GB&version=3" type="application/x-shockwave-flash" width="560" height="315" allowscriptaccess="always" allowfullscreen="true"></embed></object>
LnBmad
Any chance I can get a link to the vid please as my iPad doesn't want to show it me on the forum lol. Might be a case of fitting a summer lands chuffer then so I all comes out the bottom of the loco rather than out the top... Was only considering them as she throws a lot of condensate out of the cylinders every time she starts.
LnBmad
