Chuffed 2 bits sound + radio speed controller
JMORG
Post by JMORG » Tue Jul 16, 2013 4:40 pm
Hi all :)
I'm just wondering how to wire up the Mtronics speed controller with the sound card.
Does anybody have a diagram to show how they wire up?
Thanks!
Big Al
Post by Big Al » Tue Jul 16, 2013 4:45 pm
Their are wiring diagrams and instructions on Chuffed2bits and the Mtronics web sites. The Mtronic shows a Tug boat diesel sound card same as loco one.
http://www.mtroniks.net/resources/digiS ... nual_4.jpg
http://www.chuffed2bits.com/ESC%20setup ... ctions.pdf
Big Al
Post by Big Al » Tue Jul 16, 2013 10:49 pm
You will also need one of these if you want to use engine start/stop and sound the horn. One switch does all this with a spare sprung radio set lever , left hand start/stop engine sound right hand sound horn.
http://www.mtroniks.net/details1.asp/Pr ... itcher.htm
http://www.mtroniks.net/resources/microswitcher.jpg
JMORG
Post by JMORG » Wed Jul 17, 2013 1:21 pm
Ah thank you for those! :)
How does the Speed controller connect to the sound card though?
Big Al
Post by Big Al » Wed Jul 17, 2013 4:09 pm
It doesn't,  fit and set up the speed controller, test it then fit the sound card and speaker  the blue and yellow wires on sound card go to +and-- on the motor this runs the sound at motor speed. The little switch I mentioned above will start the loco engine sound and stop it and also the horn. The two white wires from sound card screw into terminal block on the switch for left and right on radio set lever.  :lol: A word of caution the red and black wires on sound card should go to the on/off switch and not to the battery direct as I found out it drains the battery flat so needs to be of when switched off if that makes sense .
JMORG
Post by JMORG » Sat Jul 20, 2013 2:56 pm
Thank you for the help! :)
I'll have a look and spend an evening on it.
All the best!
Post by tom_tom_go » Sun Aug 04, 2013 5:52 pm
I would like to see a video of this sound card in action if possible? :)
Big Al
Post by Big Al » Mon Aug 05, 2013 12:10 am
It's the chuffed2Bits one that I used Tom. Click on picture.
All below supplied by Chuff2Bits.
Post by tom_tom_go » Mon Aug 05, 2013 10:16 am
Hi Al,
I like the sound of this as it uses the boat module from Mtroniks which is a real 16-bit sample, however, do you find the sounds are not in sync with the engine movement?  I can't really tell from your video but the one on the Chuffed2bits site is really out of sync.
Yes I am picky but I am use to DCC OO gauge sound models :P
