Servo problem
Vapouriser
Servo problem
Post by Vapouriser » Fri Jul 05, 2013 10:06 pm
Having fitted r/c to Ragleth at last, one servo works perfectly the other seems and sounds to be turning round and round inside continuously with the lever not moving. I pulled the plugs out and ztarted again. It worked with the arm moving a few times then it ran continuously. I pulled the plugs again. The servo was red hot. Any ideas please? Thank you.
LnBmad
Post by LnBmad » Fri Jul 05, 2013 10:46 pm
Servo is knackard
Vapouriser
Servo problem
Post by Vapouriser » Fri Jul 05, 2013 10:54 pm
And I thought I d bought new ones from a local shop! Might as well try online. Thank you.
LnBmad
Post by LnBmad » Fri Jul 05, 2013 10:57 pm
If its new then take it back. It sounds like the meshing has gone.
Post by Chris Cairns » Fri Jul 05, 2013 11:07 pm
Sounds like a gear is stripped inside the servo allowing the motor to run continuously (the probable reason it is getting hot). As has already been posted if it was bought new take it back for a replacement/refund.
