Dan's Rob roy rebuild
Thanks Jim. I'm using a lining pen. Its relatively simple to use but takes a very long time, the outer line on one side of the cab took me 2 hours this morning.
Dan,
DLR
www.freewebs.com/dlrail
DLR
It is the Bob Moore pen, I've got a book that uses bow pens more or less throughout however a friend said he had much better results with the Bob Moore pen. Today marked the end of the painting with the last coats of varnish applied to the body work.
Dan,
DLR
DLR
After a very long day of nuts, bolts and trapped fingers the rebuild is finally complete ! I didn't take any pictures during the assembly, it was pretty straight forward apart from getting the tanks in which took a little inginuity.
https://www.youtube.com/watch?v=0gi9hQGS2JQ
The star was the last thing to go on, its a familiar sight on most Caledonian locos but is often left off the models. Yesterday was the steam test which im pleased to say it passed with flying colours. Only a short video as I'm rather out of practice so was struggling for a steam.
WARNING: in the video below there is a gas burner with a terrible howl, don't have your sound up loud.
https://www.youtube.com/watch?v=REpWm-HfYY8
Dan,
DLR
DLR
With the rebuild completeits now time to do some fine tuning and finishing touches. The test run at the club track was a good start but there was still something not right. Further examination back on the bench showed that the lubricator hadn't been putting oil in, no wonder it was barking so loud ! This was traced to a piece of grit in the check valve allowing steam back into the lubricator. The hot shower when starting was also a problem so I've fitted automatic drain cocks.
These are mostly based on Dave Watkins' fitted to his Chaloner but altered to be at 90 degrees instead of in line. Since the track visit ive run the loco on blocks for about 5 hours, should have really done this before taking it as its got rid of alot of the initial stiffenss. The next track test is in about 4 weeks where hopefully I will get round without stopping
Dan,
DLR
DLR
One last update. During the last run there were some draughting issues confirmed, the loco wouldnt maintain pressure while running. In an attempt to solve this, the chimney has been sleved and a lempor style blast nozzle fitted. Another very succesful test was done at the club this evening, the loco completing several non stop laps with everything working as it should.
Dan,
DLR
DLR
Re: Dan's Rob roy rebuild
Hi
I have just picked up a Rob Roy and am interested in fitting the Auto drain cocks was this an easy job to do?
Paul
Paul
Does your Rob Roy have any kind of drain cocks fitted at the moment?
