Garden Railway Accidents
- South-Trethevy
No we could sense tantrums so we pegged it. Ah the good old days.
Cecil your engines on Fire!
Its a Mamod it does that.
Oh aye there well away now. About 3 miles did the trick.
- New Haven Neil
Here's an OMG that happened a few weeks ago on the Leodest & Larivane....
A new friend visited for the first time - he's new-ish to the island and we hadn't met, but had e mailed. He brought two gorgeous Roundhouse locos, lined by lightline....both had just been re-gauged to 45mm, as his previous line was 32mm.
Loco ran around the line perfectly - on the raised section too. Second trip around, the reverse loop is traversed the other direction - out of sight behind a large bush, is an LGB R3 point - leading nowhere currently, but screwed over to avoid accidents. Said loco disappears behind bush, and crrrunch...falls to the floor, 18'' or so, onto the only paving the line crosses - damaged bunker, cab and tank, and a very, very embarrased line owner....
Investigated the cause - turns out the Roundhouse back to back gauge is WAY too tight for LGB points, loco had picked the facing point blade and overturned.....second loco was re-gauged before running!!! He was very good about it, I was mortified. Roundhouse repaired the damage very cheaply, I think the owner is still speaking.....anyway he's coming again this Saturday!
Here's an odd thing though - my two Roundhouse locos were supplied by them for 45mm, to a much wider back to back than their own gauge indicated.....
Moral of the story - on first runs around an unfamiliar line, keep a close watch on your loco!
And to 'Trackshack John' (no connection, well, OK, connection as a friend and customer ), if you read here - you're a gentleman! I would have cried.....stropped......etc!
Neil.
Neil.
Living on an island paradise, the Isle of Man - narrow gauge trains and motorbike racing!
- Chris Cairns
As you say,
Hopefully Roundhouse will put out a warning to owners using LGB track to prevent reoccurrence.
I've joined the 16mm NGM and the local West of Scotland Group has twice monthly meetings at one of the member's railways. So far I've only managed to visit once, and not having the IP Jane ready had to take a diesel instead. Fortunately it runs at a sedate scale speed flat out, but there was a position on that line where it goes out of sight behind a garden shed. I relied on the noise generator on the diesel whilst awaiting it to reappear.on first runs around an unfamiliar line, keep a close watch on your loco
That's very interesting...I wonder if that's why so much of my stock derails on the points at Rutton? May call for some further investigation, if I ever get the time!New Haven Neil wrote:Investigated the cause - turns out the Roundhouse back to back gauge is WAY too tight for LGB points, loco had picked the facing point blade and overturned
We've had our fair share of accidents on the MVR. I remember when we built our first temporary line on breezeblocks, we had dreailments every few minutes...fortunately, we were only using the LGB stock then, which is built like tanks!
Then when Russell was brand new, we laid a circuit on the patio to run her in. However, with hindsight we laid the track a little too close to the edge, and when she inevitably derailed she rolled right off and landed in a flowerbed! Fortunately, there was no damage done, but I was mortified that such an accident should befall my new pride and joy, and refused to run her again for some months afterwards for fear of a repeat performance!
The most serious accident since the MVR proper opened was a couple of years ago, when Russell was being piloted by a visiting Millie. For some reason she derailed on the curve round the big conifer, came right off the track and was only saved from falling into the flowerbed below by the coupling chain linking her to Russell! (Shades of the the Railway Series story "Bulldog"!) It was lucky that coupling chain held, as I wouldn't have fancied having to retrieve a hot engine from an area completed closed in by the breezeblock trackbed and the tree....
- New Haven Neil
Long while since a post on this, but here is a pic of PTLRcecils Beeson/Beck engine Gussie off the road on the "other" Silverdale light railway of Peter Hutton. Note he gave me permission to put it on the forum just before he took it on my camera
"What the hell is that?"
"It's a bit big isn't it?"
- bungle80a
I think it'll need a little more than a jack to put that loco right, but i'll let Cecil explain waht he's done to it!
All I can say is.....
....WHOOPS!
....WHOOPS!
Bungle80a
"Who has stolen the 3 link coupling off the end of my train?!?!
.....[a few minutes pass hunting down replacements].....
"So, which comedian has uncoupled my entire train?!?!"
As a postcript to my above post, a few weeks ago my brakevan K2 caught some very dry and stiff overhaning branches on the curve round the big conifer. It fell off the wall, and before I could grab it the rest of the train had been pulled of as well! Fortunately Russell stayed on the wall, but one of K1's couplings broke off, as did one of W2's wheelsets and U1's roof! U1 is now repaired, but one of W2's axlebox bearings is lost in the undergrowth so I shall have to write to IP and ask for a spare before she can run again...
Is that the cowcatcher breaking off on the way back from the SLR or something else?bungle80a wrote:I think it'll need a little more than a jack to put that loco right, but i'll let Cecil explain waht he's done to it!
....WHOOPS!
I did, and it still took the bloody paint work off.
Wait did I just post that on the internet. Drat Drat and double drat.
