Uncoupling Tool - Accucraft Chopper Couplers
- AvontuurNG15
Hi All,
Has anyone come up with a tool for uncoupling Accucraft chopper couplers?
Charles Collins
Charles Collins
Unbend a paper clip and push one end into a cork
Dan,
DLR
www.freewebs.com/dlrail
DLR
- AvontuurNG15
- Dr. Bond of the DVLR
- Retired Director
you bend the paper clip in such a way that you can push a bit through in between the chopper faces and then lift up, in doing so both the hooks are lifted up simultaneously. The cork is just to help hold it and make it look less like a bent paper clip and more like a proper tool.
- AvontuurNG15
- andymctractor
I use a blunt craft knife but any thin blade will do. Place the blade between the faces of the chopper under the hooks. Push the stock together to close up the coupling then lift up the blade together with the hooks pulling the blade away as the stock is separated.
I did have a more sophisticated version but I think it went missing on an open day I visited.
Andy McMahon
Andy McMahon
- paullad1984
- Palmerston
