It has now come to the top of my workshop 'To Do' list. I have searched through the Forum but cannot find a specific build topic for AnDel model kits (they are generally easy to put together) with just a couple of photos of this Guards Van posted, which I believe was withdrawn in 2009.
I found Zach's Topic where he had to rebuild his Guard's Van after being attacked by a cat, but it does not finish with whether the article on working brakes was ever submitted to Garden Rail and published - http://gardenrails.myfreeforum.org/abou ... el&start=0
Originally I considered making the side doors working but felt the van would lose some of its strength by cutting the doors out of the side walls, however I do intend to fit hinges to the inner door as I would like to decorate the inside of the van. The late Peter Longfils did an excellent job of fitting out his van although my skills will not be as good (here are his photos).
In order to view the interior a removable roof would be a good idea (I am painting the window frames white and will be fitting glazing). I am aware that these resin roofs may need softening by immersion in hot water. However will they retain their new shape once cooled down again. My idea is to make a wooden frame which would be a friction fit within the 'cabin' of the van but not holding the roof in place over the balcony - would that idea work?
And what colour would you paint the buffer beam (it has the moulded resin buffer with an under slung coupling chain and top hook in black) - red or black?
Thanks for reading this Topic. Any & all answers most appreciated.
