(WH)WHR Rolling Stock
Re: (WH)WHR Rolling Stock
Last week saw me complete the latest project, the two NWNGR/WHR slate wagons bashed from Lineside Hut kits, and the re-Ffestification of the Binnie kit that was previously representing that type of wagon. And here they are:
I ought to get back to my carriage projects really, but I find building small wagons awfully distracting, and I could do with a few more WHR ones to make up an authentic train...
They all look great Andrew, particularly No. 38 showing years of hard work.
Hi all,
More slate wagons underway here, this time on modified Phil Sharples flat wagon kits.
One will have a plastic strip representation of an iron body, using the jig I created for a similar wagon a while ago, and the other will be another all wooden one. Based on the few photos and relatively small amount of information about WHR/NWNGR slate wagons (of which there seemed to be a surprising variety) , both will have dummy "W" iron type axleguards rather than the Ffestiniog or pedestal sort. So far I've modified the chassis and built the bodies:
I've also been experimenting with slate loads. I decided that life was a little short to make them, so purchased three sizes of Lineside Hut ones to experiment with modifying them (ie a little "cut and shut") to fit my WHR wagons. I'm pretty pleased with how they came out and will purchase some more in due course. If you look closely you can see the steel screws in the top to allow wagons to be loaded and unloaded with my fancy magnet on a stick device...
I'm hoping to get some time to begin painting the new wagons at the weekend, and to start work on the axleguards, maybe...
Nice slate loads Andrew.
The Jig looks brilliant and it seems to make the job of making the wagons a lot faster and easier.
Morning all!
Another slate wagon update, I'm afraid - what else do you expect, when the Welsh Highland had about 100 of 'em, and the Ffestiniog over a thousand?! Actually, I think I'm only going to build a few more after these ones, but that's for another time...
For now, here are the latest two:
They're based on some grainy and rather unclear photos of original WHR wagons which had "W iron" axleguards, and those horseshoe-shaped bits of strapping (anyone know the name of those?!). Otherwise, they're similar to the ones I've already made.
I couldn't find any suitable axleguards, so I made them from plasticard and wedge-shaped bits of Lego - they're an approximation at best! The "horseshoes" are just nylon washers cut in half.
I was planning to return to carriages, but then came across a picture of an intriguing little dropside wagon, Ffestiniog No 27, which you can see here: http://217.34.233.120:8086/index.php?a= ... 5679046704. It's the only image of this that I've seen, and I don't know of any drawings, but happily it stands next to an early coal wagon, which looks pretty much the same size, other than the height. Even more happily, I was given a Phil Sharples kit for one of those for my birthday last month, so I got to work, by simply cutting off the top two planks:
I also cut the dropside door out - I don't intend to make it opening, just thought it might look more realistic. I hindsight, I'm not sure it was a great idea, it'll make the whole wagon weaker, and MDF doesn't really like being messed about with, but we'll see...
Intriguingly, the iBase caption refers to this as the "oyster wagon". Some quick research has revealed that there was indeed a trade in oysters from Porthmadog - that seems to have been principally by sea to Liverpool, but I guess some maybe went by rail, being shipped from port to main line via the FR? It appears that oysters were shipped in ice-filled barrels - if those needed to be kept upright, I suppose a dropside wagon would have made it easier?
Or, is it like the "beer wagon", in that there's a photo of it somewhere in which it just happens to be carrying such a load, rather than being designed specifically for the purpose? Does anyone know more?!
Interesting. I had seen photos of those dropside waggons before, but I hadn't realised how big they were! I had always assumed they were slate waggon sized.
I think I assumed it would be smaller too, but it does look about right in comparison to the photo, I think?
I really like this little NWNGR dropside open: http://217.34.233.120:8086/index.php?a= ... GAWTpg/111
I have made a model of it, which is attractive, but not very accurate! I used a Phil Sharples chassis again, but then had to modify the dimensions to suit, so I don't think the proportions are quite right:
I like them Andrew. Very nicely weathered too
Really nice collection Andrew, well made and finished.
Do you have a "to-do" list of wagonry, or are you just going and going until you've a complete WHR/FR roster in 16mm?
I don't always comment when I pop back in for a look, but this is one of my favourite threads here. Always an inspiration.
Thanks Aaron, I really appreciate it! I'm looking forward to the time when we see your builds in progress again...Old Man Aaron wrote: ↑Sat Feb 11, 2023 9:51 am Do you have a "to-do" list of wagonry, or are you just going and going until you've a complete WHR/FR roster in 16mm?
And yep, I have a "to do" list.
It goes something like this, in (very!) rough priority/likelihood order
WHR (or possibly FR?) Meat Van No 1, quarrymen's coach conversion. Probably from an H Jones engineering kit, which I think he's working on now.
WHR bolster pair and runner - maybe based on Phil Sharples flat wagons again.
2 x WHR slate wagons, iron body, wooden chassis, as previously.
WHR bogie flat converted from NWNGR Ashbury brake. This one might jump the queue ahead of the bolsters, either will do for carrying timber.
WHR small open, as previously but with FR type axleboxes, maybe a sand load.
WHR dropside open number 123 - because who wouldn't want a wagon number 123?!
FR flat/slab slate wagon - might jump the queue just because it should be quick!
FR "1000 series" slate wagon - like my previous 2 ton wagons but with different brake gear. Just because I fancy it, really.
NWNGR ridge-roofed van - didn't actually survive until the 20s, but... Possibly based around another PS FR coal wagon kit.
FR Cleminson coal wagon - looking forward to seeing how Peter's turns out...
The other WHR closed van, with the curved tops to the doors.
The other WHR brake van.
FR granite wagon, 3T slate wagon conversion.
And, maybe...
FR "Feldbahn" bogie open
FR crane!
Somewhere about a third of the way through that list I'll have built 50 WHR/FR wagons - I think a goods train running day will be called for!
When that will be is anyone's guess. I've also got about a dozen more carriages to build, including two that are almost finished and really deserve some attention!
Cheers all,
Hi all,
In what was record time for me, the "oyster wagon" is now complete:
I couldn't resist trying to recreate the photo which inspired it (http://217.34.233.120:8086/index.php?a= ... TjNZw/1011):
I think the recreation possibly suggests that the completed wagon is about a scale foot/18" longer than it should be, but that might just be the angle - I should have moved a degree or five to the left to get my recreation spot on, I think, which would have foreshortened the wagons a little...
I've made a barrel load to go inside it, will give a test run at some point...
You're getting really good at this Andrew. The wear and tear to the planking is very nice, and subtle weathering is particularly good.
I think you are being too hard on yourself. trying to guess dimensions from angled photos without any real reference points is almost impossible. Looking at the side-on coloured photo of your model, if 16 - 24mm was taken off the length it would be far too short, IMO, and the model looks good and believable to me ( weathering is nice as well )Andrew wrote: ↑Mon Feb 20, 2023 11:24 am
Thank you!Peter Butler wrote: ↑Mon Feb 20, 2023 11:49 am You're getting really good at this Andrew. The wear and tear to the planking is very nice, and subtle weathering is particularly good.
I was thinking that, when - in a few builds time - I get round to my half-century of FR/WHR wagons, I ought to make something I can number "50" and leave it almost "ex works" condition. I'm going to struggle though - I'll be itching to attack it with the sandpaper!
Not really, don't worry, I'm pretty pleased with it. If it is a little out here and there, that's fine - any inaccuracies are a small price to pay for the speed and convenience of using the Phil Sharples kit as a starting point. Plus, there are very few people who can point out what those inaccuracies are!
That's my philosophy too!
You did a superb job on the weathering Andrew. You sure are a master at it, you have lifted the goal post to a level that most of us only dream of, which I do every time I have ago at weathering my stock.Andrew wrote: ↑Mon Feb 20, 2023 3:55 pm I was thinking that, when - in a few builds time - I get round to my half-century of FR/WHR wagons, I ought to make something I can number "50" and leave it almost "ex works" condition. I'm going to struggle though - I'll be itching to attack it with the sandpaper!
Do two of those "50's" Andrew and keep one 'ex works' and the other do another masterpiece with it.
I don’t know anything at all about this kind of thing — but it looks to me like a pretty neat reproduction of the item in the pic. Cool!
Absolutely!! I couldn't agree more. I've rarely seen such an accurate representation of weather worn wood and scuffed paintwork.Peter Butler wrote: ↑Mon Feb 20, 2023 11:49 am You're getting really good at this Andrew. The wear and tear to the planking is very nice, and subtle weathering is particularly good.
I'd love to know the secret.
