Post
by jim@NAL » Sat Oct 27, 2012 1:55 pm
i want to make some gutter and down pipe for my station im going to use straws for my down pipe any idears what i can use as the gutter please
Si
Post
by Si » Sat Oct 27, 2012 2:59 pm
Have you tried cutting the straws in half, long ways, or is it too fiddly?
Post
by jim@NAL » Sat Oct 27, 2012 4:58 pm
tryed that not quite big enoth found some old felt tips cut them in harf has worked well
Post
by MDLR » Sun Oct 28, 2012 5:52 pm
For gutters, you would've needed Macdonalds straws..............
ptlrcecil
Post
by ptlrcecil » Mon Oct 29, 2012 12:48 pm
Does plastistruct do something similar?
Si
Post
by Si » Mon Oct 29, 2012 1:46 pm
Could always use some tin - cut into strips and then rolled around some dowling (or whatever you have of the diameter that you want). I'm a great fan of tin as it's easier and cheaper to get hold of than brass and just as easy to work (well, at least for the stuff that I do with it).
Post
by jim@NAL » Mon Oct 29, 2012 10:21 pm
cut down felt tip pens and a bit of a bendy straw for down pipe thank you for your help
