IPM03 Replacement Safety Valve for Mamod Steam Locomotive
This section is useful for posting interesting copies of instruction manuals and similar pieces to help other members of the hobby
Post by Chris Cairns » Sun Oct 21, 2012 7:23 pm
To replace a previous GRRL Topic which was deleted after my Photobucket photos could not be accessed, I have rescanned the instructions provided with this replacement valve.
I do not have one of the replacement safety valves produced by Dream Steam or RWM (formerly PPS), but I assume they are of a similar construction. The one fitted to my Mike Chaney replacement boiler is not adjustable.
So they have a hollowed out body, a stainless steel ball, a rod with a cup shaped to sit on top of the ball, a spring and a threaded cap which has 4 exhaust holes. These are set to about 20-25 PSI for fitting to a Mamod, but by using something like the small circlip pliers that I use into those exhaust steam holes you can screw in the threaded cap to increase the pressure to approx 40-45 PSI.
