Water Top Up Valve
Crackingjob
Water Top Up Valve
Re Mamod SL1
The Water Top Up Valve which allows water to be pumped into the boiler a little at a time during running, is leaking.
The silicon band is torn.
Rather than buying a new valve at £8, can I obtain silicon tube to replace the torn section??
Any ideas
Crackingjob
Any ideas
Crackingjob
- Chris Cairns
Silicone Tube, ideally Inside Diameter 2mm and as thin walled as possible, max Outside Diameter 5mm, otherwise it will not enter the boiler insert.
Most radio control fuel silicone tubing is a bit thick walled, but if this posting has the correct sizes it should do - http://www.ebay.co.uk/itm/White-Silicon ... 4cfe7c6125
Make sure you clean up the shaft prior to fitting the tubing (I use some brasso for this) and cut the tubing a little shorter in length than the shaft - gives a better water tight seal.
DLRdan
Crackingjob
