Project L
anythingsdr
Project L
Post by anythingsdr » Sun Aug 12, 2012 4:15 pm
Leaves on the line? Grass Cuttings on the ballest? Fluffy Seeds an issue? Not for much Longer on the Devon Hilly Railway & SDGRG. Having got totally fed up clearing fluffy bits and grass off engines, I've come up with this:
Leaves? What Leaves?
Alistair Parsons,
Apprentice Multi Skilled Technician
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Sun Aug 12, 2012 6:34 pm
is that 4 computer fans strapped together?
anythingsdr
Post by anythingsdr » Sun Aug 12, 2012 7:08 pm
It was 4, but back to 3 big ones as the little one didnt really help!
Alistair Parsons,
benchmark
Post by benchmark » Sun Aug 12, 2012 7:13 pm
Mr. Bond of the DVLR:73727 wrote:is that 4 computer fans strapped together?
Yes, it looks like it.
Unfortunately, i hate to be the bearer of bad news but aerodynamic basic laws state the 4 fans strapped together in series does not give a 4 x multiple effect as each fan will obstruct the flow of the previous fan when the air hits the blades. The air from one fan decelerates to almost zero when it hits the blades infront of it.
Try it for yourself by comparing only 1 fanin one hand vs 4 series stacked fans in the other. There will be no significant difference in airflow.
benchmark
Post by benchmark » Sun Aug 12, 2012 7:14 pm
anythingsdr:73729 wrote:It was 4, but back to 3 big ones as the little one didnt really help!
Ah , you found out for yourself i see. :lol:
anythingsdr
Post by anythingsdr » Sun Aug 12, 2012 8:03 pm
Yeah :) Two came out strapped together for some unknown reason!
Alistair Parsons,
Post by tom_tom_go » Sun Aug 12, 2012 8:41 pm
He he, great use of old PC parts ;)
Tom
Crackingjob
Post by Crackingjob » Mon Aug 13, 2012 9:18 am
Anyone else using recycled computer parts...AND screws are not included in that
WVLR
Post by WVLR » Mon Aug 13, 2012 6:03 pm
Yes, my data wagon, for measuring speed and distance, uses the optical encoder from a Logitec mouse (ball type) driven from one of the axles with a Delrin chain.
Mike
Mike
Wood Valley Works
http://www.woodvalleyworks.co.uk
Wood Valley Light Railway
http://www.wvlr.co.uk
Post by Narrow Minded » Tue Aug 14, 2012 12:55 am
I've used the wiring and connectors quite regularly, a CD tray and the plastic "CD" spacer from a tub of CDs to make a wagon turntable, a speaker from a laptop to put the sound card into a Simplex, tiny fan from the same laptop to make a radiator fan for a scratchbuilt diesel and parts of a PC case are currently being used as a "weedblock" and foundation for part of the Quarry Extension ;)
Scrapping anything in this household is akin to the Cajuns killing a pig - "The only thing not recycled is the squeak!" :lol:
Sandbar
Post by Sandbar » Wed Aug 15, 2012 11:02 pm
I used the cd player as a base for a railway crane. Simply remove the circular bed and screw you crane onto the bearing underneath. It revolve so freely that the small breeze from a passing train can actually turn the crane, so watch the placement if near the track. Mine actually manage to hook onto the loco!
Great ideas for reusing the old computer parts, especially if you convert the power unit over to general purpose use around the railway with the different voltages.
Regards from Andrew
Sandbra & Mudcrab Railway
Gremlin
Post by Gremlin » Wed Aug 15, 2012 11:22 pm
A PC heatsink made an interesting wagon load
Crackingjob
Post by Crackingjob » Thu Aug 16, 2012 12:05 pm
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Excellant ...photos???????
