Sl1 problems..
made-in-england
Sl1 problems..
Post by made-in-england » Wed Aug 20, 2008 11:31 am
My Sl1 has a new uprated saftey valve to be fitted but i can get the whistle of to put it in its place as the whistle bar goes through the cab which stops the turning of thw whistle.
Help please
mhlr
Post by mhlr » Wed Aug 20, 2008 12:16 pm
the actual whistle is the bit that unscrews, not the bar. get a small spanner and undo the whistle bit, then the bar will just slide out from the cab.
made-in-england
Post by made-in-england » Wed Aug 20, 2008 3:55 pm
Ok will doo
cheers
Chris
Post by Chris » Wed Aug 20, 2008 8:14 pm
It might be a bit scaled up, but should undo ok with a spanner. I use a mini adjustable bought from ebay. Just be a bit careful not to use too much force.
