Leaves on the line!
- planty
Leaves on the line!
How do people keep leaves off the line? My railway meanders around a flower bed and as such gets a covering of dried up leaves that handily derail small engines. It's a constant battle to keep clear.
Also any tips for keeping plants under control or away from the track? I tried some netting and canes to keep things back, but this has a habit of getting pushed towards the track and then acts as a net that's great at catching handles from carriages!! Must check my loading gauge!
PeachBottom
benchmark
- planty
Though it's "prototypical", loose ballast is a nightmare for all sorts of reasons (some locations being worse than others). Far better to bond it somehow (there are several well documented methods), and again in certain locations even this is "prototypical"!I find a stiff brush removes a lot of the loose ballast under my track though
laurence703
http://www.youtube.com/watch?v=AkLZjsraahI&feature=plcp
Removing leaves (and hedgehogs) Using a toilet brush of all things...
The entire series is on there by the way
benchmark
If you skip to 12:00 in the video you see him build the toilet brush cleaner.laurence703:73201 wrote:http://www.youtube.com/watch?v=AkLZjsraahI&feature=plcp
- planty
- Dr. Bond of the DVLR
- Retired Director
IrishPeter
Strange as it may seem I use a leaf rake! The worst culprity for dropping leaves n the line is not the pines - though they produce some nice long needles that can cause derailments, but the scrub oaks which drop copious amounts on to the line at unusual times of the year - like April when they are stressed due to lack of moisure!
Peter in AZ
Peter in AZ
