Chris
Post
by Chris » Wed Aug 13, 2008 7:26 pm
Not as good as my coal staithe, but I made this water tower from a couple of old tin cans and a soap dispenser.
Then the water reaches towards the top of the tank it overflows down a tube and to the arm of the old soap dispenser.
Well, it is a bit of fun, and only cost a squirt of paint.
SillyBilly
Post
by SillyBilly » Wed Aug 13, 2008 7:41 pm
Just like your coal staithe very nice work.
riveresk
Post
by riveresk » Wed Aug 13, 2008 8:10 pm
Nice piece of work.
steamyjim
- Retired Director
Post
by steamyjim » Wed Aug 13, 2008 9:42 pm
Very very nice!
mhlr
- Retired Director
Post
by mhlr » Wed Aug 13, 2008 11:29 pm
wow neat!!! I need to make one, but it's probably going on the side of a plank (so a low relief type), but I want it to work somehow. I was thinking of making it working with a pump bottle that connects up behind the wood plank, so I can fill my Edrig prototypically (nearly!!).
steamyjim
- Retired Director
Post
by steamyjim » Thu Aug 14, 2008 2:14 pm
mhlr wrote:wow neat!!! I need to make one, but it's probably going on the side of a plank (so a low relief type), but I want it to work somehow. I was thinking of making it working with a pump bottle that connects up behind the wood plank, so I can fill my Edrig prototypically (nearly!!).
What about just having a valve but making the tower higher than the locos. Then you just use gravity to feed the boiler and the valve to control the flow
SillyBilly
Post
by SillyBilly » Thu Aug 14, 2008 2:55 pm
It's been done in Garden Rail recently Jim.
Chris
Post
by Chris » Thu Aug 14, 2008 4:57 pm
Think I would be a bit concerned about getting bits of dirt in the boiler, would have to be careful about keeping everything clean.
SillyBilly
Post
by SillyBilly » Thu Aug 14, 2008 5:08 pm
Lid!
made-in-england
Post
by made-in-england » Thu Aug 14, 2008 5:40 pm
Teapot
steamyjim
- Retired Director
Post
by steamyjim » Thu Aug 14, 2008 7:02 pm
SillyBilly wrote:It's been done in Garden Rail recently Jim.
Has it, i shall have a look through my collection...obviosly missed/forgot that
mhlr
- Retired Director
Post
by mhlr » Thu Aug 14, 2008 8:54 pm
steamyjim wrote:mhlr wrote:wow neat!!! I need to make one, but it's probably going on the side of a plank (so a low relief type), but I want it to work somehow. I was thinking of making it working with a pump bottle that connects up behind the wood plank, so I can fill my Edrig prototypically (nearly!!).
I said low releif! So cant have a proper one, because it would be only the front of the tower!
steamyjim
- Retired Director
Post
by steamyjim » Thu Aug 14, 2008 10:33 pm
mhlr wrote:steamyjim wrote:mhlr wrote:wow neat!!! I need to make one, but it's probably going on the side of a plank (so a low relief type), but I want it to work somehow. I was thinking of making it working with a pump bottle that connects up behind the wood plank, so I can fill my Edrig prototypically (nearly!!).
You could have a semi circular tank?
mhlr
- Retired Director
Post
by mhlr » Fri Aug 15, 2008 12:24 am
no: 1) because I need a very flat front for clearances, and 2) whats the point, it would hold enough water (we aint just filling up Mamods here Jim, Edrig has a huge boiler).
steamyjim
- Retired Director
Post
by steamyjim » Fri Aug 15, 2008 8:29 am
What about a hand pump mounted in the fake tank? With a realy tank hidden somewhere-lineside hut or similar
SillyBilly
Post
by SillyBilly » Fri Aug 15, 2008 3:02 pm
Because when you use a syringe it doesn't take 10mins to fill the boiler.
steamyjim
- Retired Director
Post
by steamyjim » Fri Aug 15, 2008 5:32 pm
SillyBilly wrote:Because when you use a syringe it doesn't take 10mins to fill the boiler.
stuh256
Post
by stuh256 » Tue Jun 22, 2010 10:28 pm
I just built a water crane using a wndscreen washer pump to pump the water up a pipe through the track base through a dummy water crane into the locos. Will put up some pics tomorrow!
Post
by Narrow Minded » Sat Jul 03, 2010 12:14 am
.................................................looks at calendar
