Lots of useful info here for the modeller.
- flattened ends of the handrails
- square holes in the headstocks, side chains removed
- single tail lamp bracket
- different sized carbide reservoirs
- flexible pipe between the two reservoirs
- route of the thinner gas pipe up and across the carriage
- AFAIAA that is a lighting circuit cable around the bend of the gas feed; but as it's such a long time since I've looked at L&B coaches I can't remember which one this is (no steam heat, which IIRC is A Clue)
- vac pipe and route - note that the bag has been left off the dummy, so I reckon this has been shunted in to the bay at Lynton and left with the vac brakes 'on'
- beading detail at the top at the roof joint
- second handrail on the roof
- no gutter pipes off the landers
- gas gauge (I think) facing the platforms on the RH carbide reservoir.
- footboard brackets on the headstock, note the outer bolt is shared with the headstock bolts
