dewintondave
Post
by dewintondave » Sun Aug 23, 2020 11:26 pm
tom_tom_go wrote: βSun Aug 23, 2020 12:23 pm
Lovely Dave, runs very smooth. I like the clicking noise as well.
The mechanical lubricator on my 5" gauge loco is of the clutch type which although works well I am concerned longer term it will fail and I will end up with seized cylinders!
Thanks Tom, it's a lovely project. LBSC would call it watchmaking
It's good to be able to see the winding handle going round rather than back and forth
Best wishes,
Dave
dewintondave
Post
by dewintondave » Mon Aug 24, 2020 3:06 am
- DSC00502.JPG (296.1 KiB) Viewed 4035 times
Drive shaft and eccentric
- DSC00511JPG.jpg (21.4 KiB) Viewed 4035 times
Test pumping
- DSC00512JPG.jpg (45.73 KiB) Viewed 4035 times
Milling the ratchet wheel with homemade cutter
- DSC00527JPG.jpg (30.95 KiB) Viewed 4035 times
30T 36T 42T Ratchet wheels - hardened
- DSC00530JPG.jpg (20.12 KiB) Viewed 4035 times
Ratchet wheel and fixed pawl
- DSC00522JPG.jpg (20.1 KiB) Viewed 4035 times
- rsz_dsc00555.jpg (56.7 KiB) Viewed 4035 times
Best wishes,
Dave
Post
by FWLR » Mon Aug 24, 2020 10:03 am
bambuko
Post
by bambuko » Mon Aug 24, 2020 10:18 am
dewintondave wrote: βSun Aug 23, 2020 11:18 pm
...I can see myself using these on future models
Thank you Dave, for details and all the additional photos and explanations
BTW what solder did you use to secure cylinder cover?
Mason just says "...solder to cylinder..." without elaborating whether silver solder or just soft solder.
I can see this lubricator being very useful in other small models as well - thank you for bringing it to our attention
I have looked at "miniaturising" LBSC's lubricator... but came to the conclusion that it wasn't very practical
dewintondave
Post
by dewintondave » Mon Aug 24, 2020 10:10 pm
Thank you Rod! I call it quiet compressed air
So many use those horrid noisy air compressors
bambuko wrote: βMon Aug 24, 2020 10:18 am
Soft solder, same for the bushes and bearings mounted to the tank
Best wishes,
Dave
Post
by Old Man Aaron » Sun Aug 30, 2020 3:46 am
Very, very impressive.
Aaron
dewintondave
Post
by dewintondave » Thu Sep 17, 2020 1:13 am
Thanks Aaron!
Well, the mechanical lubricator didn't work out. It was unreliable, so is lovingly displayed on the shelf.
The loco has run very happily with minimal oil lubrication for a long time. In fact the loco sounds best on water lubrication only. When the lubricator was working it over delivered and oil was spewed out on to the track, the exhausts and drain cock pipes were not well positioned. I have made some slip over angled pieces to redirect the pipes. Fingers crossed that it still sounds great. I'll be manually oiling the loco every lap or so through a port in the valve chest
- rsz_dsc00581.jpg (55.54 KiB) Viewed 3653 times
Best wishes,
Dave
dewintondave
Post
by dewintondave » Fri Oct 23, 2020 6:42 am
Just had a good run of the loco with a full boiler of water. Had a 35 minute run with the water ending up still above the burner tubes
I had recently made an oil injection port with a non return valve so that I can manually pump oil in with my new 1mL syringes - thanks to eBay
Here's the new oil injection port
- rsz_dsc00599e.jpg (71.02 KiB) Viewed 3438 times
Lovely slim syringe body. I was pumping in 0.5 mL for the equivalent of one lap of our circuit
- rsz_ec0159ebb006ed0262.jpg (36.2 KiB) Viewed 3438 times
Best wishes,
Dave
Post
by FWLR » Fri Oct 23, 2020 10:08 am
Thats pretty impressive Dave...
