Latest Additions to the Steam Shed (Video now added)
- Retired Director
- Chris Cairns
1st Addition Video
As 'Ginny' was still sat on my table after its photo studio session above, I decided to take the regulator apart and give it a few runs.
Sadly my camera batteries are almost dead, and I left the new ones in Aberdeen. So this video is rather short.
And for those who prefer YouTube - http://uk.youtube.com/watch?v=HnQqFUeiRlw
As you can probably hear the stove pipe chimney does not produce any chuff, and in fact just creates a trail of condensate instead.
I still have not worked out a system for filling this boiler with no sight glass. As it is the same size as a Mamod boiler, I guess I can measure how much I put into a Mamod boiler and use that figure (sadly most of my syringes have no markings left due to use).
The good news is that the gas does run out before the water (unlike my gas tank in the IP Jane).
Also learnt another valuable lesson. This loco has sprung centre buffers and I've only got 2 pieces of rolling stock with centre buffers fitted (I will be making a converter wagon out of a Mamod flatbed with centre buffer on one end & Mamod coupling on the other end). Using a 3 link chain seems to leave a large gap between the loco & wagon so I reduced that to using 2 links. This had the effect of pulling the wagon off the track when running at high speed and causing a derailment. Fortunately it does not derail the loco as it is so heavy.
- Chris Cairns
4th Addition
I have just managed to get the Mike Chaney modified Mamod running. I've removed the wheels for fixing, and put in a not so loose driving axle. It takes about 1/3rd of the servo movement to get enough steam through to get the pistons moving and at least 2/3rds of the movement to get any wheel speed. So I guess once this loco has been run in again and is free running, I can adjust the start point of this servo arm to get some smooth slow running. Water gauge tube is excellent, works very well.
- Retired Director
