Lubrication
- Sir Clothem Cap
Lubrication
I have always oiled my mamods as well as I can before a run but Would like an east fit oiling system for my engines. Would anyone like to reccomend a good system?
- Sir Clothem Cap
Simplified explanation. Remove the steam pipe from the reverser block, insert one leg of the lubricator in its place, then insert the steam pipe into the joining piece on the other leg.
The only complications are bending the lubricator pipe legs to shape and cutting the steam pipe to length, both of which are easy enough to do.
Full instructions are supplied and if you want I can pm you photo's which show one fitted so you can see what goes where
Pendo Pilot
