The trader told me it was a kit loco, and as it was fitted with a meths burner he recommended fitting a lubricator.
This is the meths burner which has been identified as an MGM Engineering one. The water top-up valve is the kind that Cheddar Models used to produce, and the safety valve is again unidentified and goes off at about the same pressure as the Mamod safety valve but at least it goes into a fountain upwards when it blows!
This loco is more of an SL1 than an SL1K, as the sidetanks are obviously SL1's, the cab front had a lot of paint loss and I've badly repainted it (it was an SL3 one), and the original cab back was also from an SL3 but that has gone to another enthusiast for his backless SL3, and has been replaced by an SL1 one. The boiler is the screw on backplate which is good.
I purchased and fitted an IP Lubricator, but as I've stated before on this forum it was very ineffective, so I will look at fitting it with a bigger feed pipe in due course to see if that will increase its poor performance. The boiler caused a lot of problems, so it was paint stripped, the bush for the steam nut has been resoldered, the solder fillet on the bottom replaced, and the steam pipe was re-bent to allow it to go right up into the steam dome and stop the condensate that I was getting whilst running (just like my MSS Saddle Tank).
I believe those pistons to be the upgraded 'O' ring type and these have required a lot of lubrication to get them going. Whilst I am still considering whether to fit a Roundhouse type lubricator or stick with the IP Eng one once modified, I've adopted a tip that I read on another Yahoo group.
Fit a silicone tube to the exhaust pipe to bring it to the top of the chimney, put the reverser fully forward, inject some steam oil into this tube, and turn the wheels backwards to suck this oil through the reverser and into the cylinders. Not too much oil or turning the wheels for too long will prevent oil getting into the boiler.
I was originally going to call this loco 'Iver' as I got some 'Iver' nameplates from the Cheddar Models sell-out at Merstham in 2005, but as I've now got a Cheddar Iver it will be called 'Archie' instead, after my late Grandfather who used to take me to that great model railway venue in Glasgow, the Clyde Model Dockyard, to buy some bits for my OO gauge model railway when I was a lad.
When I get the workbench built and have practised my spray painting skills, it will be repainted in red with lining and nameplates, and I've obtained the following bits to enhance it's looks.
L to R - Lamps and Lamp irons, plus brass tools from Brandbright, Tool box and brass whistle from IP Engineering clear-out (the 2 cylinder covers which had been badly punched to look like rivets will now be fitted to my IP Jane).
Thanks for looking.
