PCLR
Post
by PCLR » Fri Jan 08, 2010 9:06 pm
oh ok good then for two ip 4 wheel coachs
(the open air ones)
Buckinghamshire Railway Centre !!
VAMES!!
keeping steem alive if a little smaller!
Michael
Hancockshire
Post
by Hancockshire » Fri Jan 08, 2010 9:35 pm
Can I design the body for you using CAD?
PCLR
Post
by PCLR » Fri Jan 08, 2010 9:53 pm
yes please do can you keep it sqare and brown with PCLR in bold white letters on the side
VAMES!!
Michael
Hancockshire
Post
by Hancockshire » Fri Jan 08, 2010 9:59 pm
Square & brown. Right ho. I'll use my guards van for dimensions.
PCLR
Post
by PCLR » Fri Jan 08, 2010 10:00 pm
thanks i may them as blue prints!!!
VAMES!!
Michael
PCLR
Post
by PCLR » Wed Jan 13, 2010 7:11 pm
A little procress on the tram i have overhaul the mamod minor (steam heart) i have also orded many meccano sprocket and some chain i have work out a ratio of 6:1 i have also cut the buffer beam also going to a hardware shop to get some oak for the chassic
off the next two weeks its real going to come together
VAMES!!
Michael
SillyBilly
- Retired Director
Post
by SillyBilly » Wed Jan 13, 2010 7:25 pm
PCLR wrote:i have work out a ratio of 6:1
That's going to be quite quick I would've thought, what's the RPM of these things?
PCLR
Post
by PCLR » Wed Jan 13, 2010 8:17 pm
about 550 rpm 6 try on the fly = 1 turn of the wheels
VAMES!!
Michael
Dr. Bond of the DVLR
- Retired Director
Post
by Dr. Bond of the DVLR » Wed Jan 13, 2010 8:18 pm
Hmm, I once had a go and used 1:12 gearing which gave a slow and powerful run with a mamod minor, but then I really love trains running slow!
PCLR
Post
by PCLR » Wed Jan 13, 2010 8:21 pm
my ratio is an esterment i think i can get a 10 to1 which it better
VAMES!!
Michael
- Retired Director
Post
by Dr. Bond of the DVLR » Wed Jan 13, 2010 8:23 pm
That would be much better! More power that way too!
PCLR
Post
by PCLR » Wed Jan 13, 2010 8:25 pm
yeah i like power it will aonly pull some open air carrages
VAMES!!
Michael
PCLR
Post
by PCLR » Thu Jan 14, 2010 7:42 pm
some for procress
mamod minor finish will exhast and 3/4 sprocket
the 2 inch and anothere 3/4 sprocket
also the brass gear which will rever the rotaion
the first run at plesy2105
the steam engine finsihed
i have borded out the cylinder from 9 to10 mm to gove me an efficany of 0.23%
the main tranmission link to the gear box
VAMES!!
Michael
- Retired Director
Post
by Dr. Bond of the DVLR » Thu Jan 14, 2010 8:47 pm
Looks to be a promising project! what gear ratio are you going to go with in the end?
PCLR
Post
by PCLR » Thu Jan 14, 2010 8:56 pm
not sure yet got a lot of gears just need to put then in the right place
VAMES!!
Michael
PCLR
Post
by PCLR » Fri Jan 15, 2010 7:23 pm
more importeant procress the gear and motion work is finish, i spent a lunch time at school sweat of a lathe turn and milling sprockett out
here the results
the bussiness end of the operation i got a ratio of 14:1 wthich will be great!!!
VAMES!!
Michael
- Retired Director
Post
by Dr. Bond of the DVLR » Fri Jan 15, 2010 7:35 pm
Gosh this tram will be quite long then?
- Retired Director
Post
by Dr. Bond of the DVLR » Fri Jan 15, 2010 7:39 pm
Sorry I originaly missed the start of this thread, are you still going to steam ekectric it or just steam power?
PCLR
Post
by PCLR » Fri Jan 15, 2010 7:53 pm
just steam power them there no need to mess around with electricls
the tram will be the same wheel base and length as an edrig but 1 cm wider
VAMES!!
Michael
PCLR
Post
by PCLR » Sat Jan 16, 2010 8:51 pm
THE BIG NEWS !!!
The chassic is finish the steam heart is finish and mounted and the gearbox and body is not
url=./myff/692457/DSCN0215.jpg]
[/url]
VAMES!!
Michael
