Starting with Battery and R/C
VicRail10
Post by VicRail10 » Sun Sep 13, 2026 4:27 am
Hello,
I'm looking to start with R/C, and I'm rather lost. I'm in Australia (Melbourne), so it's not super easy to get hold of stuff. I'm wondering what system others use, and where you purchase things.
Any advice is welcome.
Re: Starting with Battery and R/C
Post by philipy » Sun Sep 13, 2026 5:42 am
Hi and welcome.
I'm not going to try to answer your questions from the other side of the world (!) but we have a number of Australian members, some of whom live not a million miles from you, I think. No doubt they will pop up with some answers before too long.
Post by LNR » Sun Sep 13, 2026 7:47 am
Hi! and welcome to the forum, good to see another down under member.
Post by GTB » Sun Sep 13, 2026 1:18 pm
VicRail10 wrote: Sun Sep 13, 2026 4:27 am I'm looking to start with R/C, and I'm rather lost. I'm in Australia (Melbourne), so it's not super easy to get hold of stuff. I'm wondering what system others use, and where you purchase things.
Since Tony Walsham passed away and his company RCS closed down, there has been no supplier of battery-rc equipment for large scale rail models in Oz, as far as I'm aware.
I started using Deltang equipment in some of my battery powered models when Tony first introduced it to the Aust. market.
Since the closure of RCS and Deltang, I now get Deltang compatible parts from Andy at Micron Radio Control in the UK. I've found the mail order service to be good and the receivers can be supplied already set up to work the same as the older RCS parts.
Phil at RC Trains also supplies Deltang compatible bits and is a member of this forum.
As you may have guessed, I prefer to use Deltang compatible equipment, which I'm used to. There are a lot of alternatives out there, but the ergonomics of transmitters that use car key fobs, or mobile phones, or joysticks, definitely do not float my boat........
The usual electronic bits and pieces like switches, plugs and sockets, etc. mostly come from the local Jaycar branch.
Welcome to the forum and good luck in your quest.
GAP
Post by GAP » Sun Sep 13, 2026 10:14 pm
I use aircraft transmitters and receivers, these are the motor controls I use along with mylocosound cards.
https://ringbalin-light-railway.blogspo ... ed-on.html
I have re packaged one transmitter and converted it so that it controls 4 locos and I have just noticed the links to trev's blog no longer work but the forum is OK. I'll update my blog with a how did I do it description.
I was to far down the rabbit hole to use deltang and the others by the time I heard about them.
VicRail10
Post by VicRail10 » Tue Sep 15, 2026 5:22 am
I also have some questions regarding batteries. Should I start with a pre-made battery pack instead of making my own? I've been looking at GeRik's blog and dealing with battery protection boards and balance charging seems rather complex. Is it just lithium that needs all that, or does NiMh also need it?
Post by ge_rik » Tue Sep 15, 2026 6:42 am
VicRail10 wrote: Tue Sep 15, 2026 5:22 am I also have some questions regarding batteries. Should I start with a pre-made battery pack instead of making my own? I've been looking at GeRik's blog and dealing with battery protection boards and balance charging seems rather complex. Is it just lithium that needs all that, or does NiMh also need it?
If you are uncertain, it is wise to be cautious. If you get a readymade NiMh pack, it's a good idea to protect it with a fuse, such as a polyswitch. If your wiring gets short circuited, then the insulation on your leads could melt or even catch fire. (Don't ask me how I know this ...... :shock: ).
I'd also suggest getting a decent "intelligent" charger. If you went for something like the IMAX B6, you could later use it for li-ion as well as NiMH packs if your confidence increased.
Post by philipy » Tue Sep 15, 2026 9:55 am
Ok, I can understand why it all seems a bit daunting, but if you start simply and work up to the bigger, more complex, stuff, it all becomes a lot easier.
You have told us nothing about your previous experiences with model railways, or model anything come to that, or your level of technical expertise, and you have given us no idea what you want to achieve in terms of prototype, gauge, etc, so it's all a bit difficult to advise you on anything specific. So I'll assume you know absolutely nothing, until you tell us any different. :D
Having said all that a model loco in its simplest form is merely 4 flanged wheels on 2 axles mounted on a chassis and driven by a small electric motor. If it has an on-board battery then the controls can be as simple as an on/off switch or if you want to get more exotic, a small on-board speed controller with a knob you can twist. For this simplest possible loco, a standard battery of appropriate size for the motor will work perfectly although the life of the battery will be limited. This is where the NiMh batteries come in because they are rechargeable, they only need a suitable charger, but as Rik said, an auto fuse is a good safety precaution, but not strictly necessary to begin with if you just want to get something moving. Getting more exotic you can then move on to Lithium batteries and this is where it does get a bit complicated with the need for protection boards and balance chargers. Personally unless you tell us otherwise, I suggest forgetting about them to start with. If you can get a basic 0-4-0 loco to run smoothly, only then is the time to start looking at LiPo's and r/c.
Just my two pennorth!
Petersfield
Post by Petersfield » Tue Sep 15, 2026 9:43 pm
VicRail10 wrote: Sun Sep 13, 2026 4:27 am Hello,
Could I check your research has included RC Trains' guide https://riksrailway.blogspot.com/2013/1 ... r-and.html?
I have a recent acquisition which needed converting from manual to RC. I was a bit lost but took advice, including from Phil P and bought various bits. In my case, I bought a receiver (to be wired into the loco controls), a transmitter and various accessories, including a battery pack, wiring loom and soundcard. Phil suggested NiMH rather than lithium in my case, I believe the latter generally need more work/attention/expertise. Barring an initial (bizarre/capricious) hiccup, everything has worked well and I'm very happy with the set-up. Charging is simple, just plug the lead in to the socket on the loco chassis, throw the switch to 'charging' and then switch on at the mains socket. When the charger's light blinks green, disconnect and look forward to your running session! (This is almost identical to the system for charging Roundhouse battery locos).
As others have suggested, if you have more information it would be useful, whether it's a generic query or something more specific. As I've learnt recently, there's a lot of 'piece of string' questions/answers with this!
VicRail10
Post by VicRail10 » Fri Sep 18, 2026 1:20 pm
As you have requested, here's some more details.
I have little experience, with both models and electronics in general. (Not nothing though.) I'm looking for general information.
Post by GTB » Thu Sep 24, 2026 7:44 am
VicRail10 wrote: Fri Sep 18, 2026 1:20 pm I have little experience, with both models and electronics in general. (Not nothing though.) I'm looking for general information.
An issue the other day with a battery powered model brought this to mind.
I changed to using 'Eneloop' batteries some years ago. They are a low self discharge NiMh battery, claimed to still retain 65% of their charge after 5 years without being used and will last for around 2000 charge cycles. Just the thing for absent minded users like myself who don't run models often........:roll:
Here in Oz, Master Instruments make a range of Eneloop based battery packs, available in most r/c hobby shops. I normally use battery holders in my models, but have used pre-assembled Master Instrument battery packs when there wasn't space for a battery holder.
I have reservations about the chemistry in Li-Po or Li-ion cells and don't see any advantage to using them in model railway locos. LiFePO4 cells are a safer alternative if you want cells with lithium chemistry for some reason.
As mentioned by others, use a smart charger for charging. NiMh cells are more robust than Li cells, but still benefit from using a smart charger.
Also, use a polyswitch (Jaycar call them PTC fuses) in one battery lead. It is cheap protection for the battery, the motor and the electronics. Rechargeable batteries have a low internal resistance and can develop seriously high currents when short circuited, leading to enough heat to melt wiring and start fires...........
Post by ge_rik » Thu Sep 24, 2026 8:16 am
GTB wrote: Thu Sep 24, 2026 7:44 am I have reservations about the chemistry in Li-Po or Li-ion cells and don't see any advantage to using them in model railway locos. LiFePO4 cells are a safer alternative if you want cells with lithium chemistry for some reason.
For me, the main advantage of li-ion cells is they are 3.7v per cell, rather than 1.2v per cell for NiMh. A boon when space is tight inside a small loco.
Yes, they are more volatile and so need to be treated with respect. Many of the problems associated with li-ion cells seem to be associated with car and plane modellers who put a lot more stress on their battery packs by rapid recharging and overloading them. We are generally much kinder to our models.
