Cutting brass track.
Wet Woking Neil
Hi, have some LGB and PIKO set track (rather than flexi), which I would like to cut as required, this includes both straight and curved. Best way of doing this please.
Thanks.
Thanks.
Re: Cutting brass track.
I use a junior hacksaw and a small file to clean up the edges as necessary. Basic, simple, does the job.
Wet Woking Neil
Sounds good, thanksphilipy wrote: Fri Jul 31, 2026 8:50 pm I use a junior hacksaw and a small file to clean up the edges as necessary. Basic, simple, does the job.
- GAP
4 inch angle grinder with a 1mm cutting blade used here.
- WLR_CD
I use a Dremel with flexy drive, running a 1” fibreglass cutting disk. Cuts cleanly and square, the flexy drive enables this.
Martin
Martin
Preseli Chris
I find using a fine razor saw to start the cut as a guide then a hacksaw to finish off works fine for me .
Chris
Chris
Yr Tren Nesa Wedi Mynd
