Use of train cassettes for storage.
Wet Woking Neil
Post by Wet Woking Neil » Sat May 23, 2026 10:39 am
I don't have the pleasure of a shed or similar when building my relatively small layout. An answer for my OO scale is the use of cassettes to add/remove engines and stock. Do people see this as practical and do this in G scale?
Re: Use of train cassettes for storage.
Post by ge_rik » Sat May 23, 2026 12:14 pm
Wet Woking Neil wrote: Sat May 23, 2026 10:39 am I don't have the pleasure of a shed or similar when building my relatively small layout. An answer for my OO scale is the use of cassettes to add/remove engines and stock. Do people see this as practical and do this in G scale?
Yes, absolutely. Before our garage was constructed wherein I now have storage sidings, I used a form of cassette storage. Each siding had its own cassette so, at the end of a running session, I ran the stock from each siding into its designated cassette, which meant, at the start of the next session, I could reverse the process and continue the session from where I left off.
Here's my blog post describing how I made and used them - https://riksrailway.blogspot.com/2010/0 ... boxes.html
Post by GTB » Sat May 23, 2026 12:27 pm
Cassettes might work with short lightweight trains, such as a small loco and a few 4 wheel wagons. Anything longer than a metre or so will be too unwieldy to handle in my opinion.
I store my rolling stock in stackable trays and store locos in cradles that locate in carry cases. The trays and cases are designed to be used for transport by car to other locations in Melbourne, as well as between the train room and track at home.
There's a discussion on carry cases on the forum from some time ago. https://gardenrails.org/viewtopic.php?t=12920
There's probably as many carry case designs as there are modellers. How complicated you want to go will depend on your carpentry skills and tools.
My observation at local steamups is that the majority of large scale modellers default to a stack of cardboard boxes for transport.......
Wet Woking Neil
Post by Wet Woking Neil » Sat May 23, 2026 8:08 pm
:dontknow: ǰ
ge_rik wrote: Sat May 23, 2026 12:14 pm
Wet Woking Neil wrote: Sat May 23, 2026 10:39 am for my OO scale is the use of cassettes to add/remove engines and stock.
Very impressive looking Rik. Think you should sell these as cut wood kits or made. Not having a jig saw I'd be interested.
Wet Woking Neil
Post by Wet Woking Neil » Sat May 23, 2026 8:13 pm
GTB wrote: Sat May 23, 2026 12:27 pm
I think as a relatively simple idea i might end up doing this.
SimonWood
Post by SimonWood » Tue May 26, 2026 9:04 am
I have a cassette system and I like it, though I did lots of things wrong in building mine but it's "good enough" for my purposes (i.e. storing trains on cassette "shelves") that I haven't got round to improving it. I would echo what Graeme says about length (mine are 1.8m i.e. too long) apart from bogie coaches that kind of length isn't a huge advantage, you can always separate longer trains.
Wet Woking Neil
Post by Wet Woking Neil » Tue May 26, 2026 12:18 pm
SimonWood wrote: Tue May 26, 2026 9:04 am I have a cassette system
Looking at short 0-4-0 engines and small rakes of about three or four wheel coaches or wagons, they should fit on about 1.2m to 1.4m cassettes, with a design to fit on a siding for adding and removing from the track. Think I will be considering this at sometime in the future.
