LGB points electrofrog or insulfrog?
Wet Woking Neil
Post by Wet Woking Neil » Wed Apr 29, 2026 10:26 pm
Hi,
Looking at purchasing LGB track (first G scale track) including the LGB siding and station loop sets. Looking at google it says the points are electrofrog so live on both lines off the points. This would not be useful for either of the sets with multiple track powered engines. Would I be right in thinking I would require to purchase isolation track. LGB sell 10152 separation track, so break in both rails, and 10153 interrupter track which only breaks on one side.
I assume a break on the one side will suffice, it doesn't show on the LGB site how to turn on/off as required, do you need a separate two way switch connected? So for the LGB siding it will require one, and for the loop to isolate option on both lines you will require four.
Am I right in thinking I need to purchase these separately at the pleasure of £30 each?
Thanks
Re: LGB points electrofrog or insulfrog?
Post by ge_rik » Thu Apr 30, 2026 2:21 pm
A cheaper way is to buy plastic insulated rail joiners and then add your own isolating switches.
Wet Woking Neil
Post by Wet Woking Neil » Thu Apr 30, 2026 4:55 pm
ge_rik wrote: Thu Apr 30, 2026 2:21 pm A cheaper way is to buy plastic insulated rail joiners and then add your own isolating switches.
Sounds a good idea. Think I'll try that. Thanks.
