Accucraft chopper coupling parts
Do you want a specific item?
PLEASE NOTE: We accept no responsibility for loss of property or money
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Tue Apr 28, 2026 12:46 pm
My stocks of second hand accucraft chopper couplings are starting to get a little low following a flurry of activity in the C and W department. I was somewhat staggered to see how much a set costs now new!
I'm particularly after square headed versions for my rolling stock - I don't mind about the old versions without the bob-weights as most of mine pre-date that design change anyway.
If you have replaced your chopper couplings and have a load of them sitting around (or any parts) do get in touch by PM.
Many thanks indeed
Zach
Commerlad
New User
New User
Re: Accucraft chopper coupling parts
Post by Commerlad » Sun May 17, 2026 6:44 am
Hi if you know anyone with a 3d printer this might help
https://makerworld.com/en/models/227792 ... Id-2483851
Post by Dr. Bond of the DVLR » Wed Aug 05, 2026 3:06 pm
Thanks Commerlad - if I go down that route I'll probably design my own as I've been modifying the Accucraft choppers to be shorter.
If anyone has replaced the chopper by putting a buffer insert into the pockets and so has a load of parts kicking around I'd also be interested, again, particularly the square heads.
If anyone wants to swap some round headed parts for square ones I'd also be happy to do that.
