General scenic arrangements
Post by Phil.P » Fri Jan 23, 2026 4:47 pm
Possibly a little bit early for the northern hemisphere?
But I am wanting inspiration towards actually building / laying some track this year!
I am looking for 'this is how I crossed the back of the house'..
Did it work, and was it practical?
How to cope with running under (in my case Holly) an established tree. - There is a leaky fibreglass pond under said tree..
This end of the garden is in shade, so it will be damp for a lot of the time.
Then, I will be 68 this year. Tonnes of earth movement and mixing of concrete, are probably not the way to go.
Neither is running too close to the ground?
I don't really want the posed artistic details, more the 'warts and all' of the compost heap, and that pile of old plant-pots, you just can't throw away. :dontknow:
Thank you.
Re: General scenic arrangements
Post by philipy » Fri Jan 23, 2026 6:10 pm
Phil,
Firstly questions:
What sort of soil are you on?
You mention running past the back of the house - is that serious?
What sort of access will be needed through the track to the rest of the garden? i.e how many bridges and how wide?
Roughly what length of run are you after?
Will it be a straight length of track, a dogbone, a simple loop and will there be sidings/station(s)?
Sorry, but they all potentially influence how to construct the trackbase. :lol:
GAP
Post by GAP » Fri Jan 23, 2026 10:46 pm
Phil as I am about your age I (read my knees) decided that crawling around on the ground was for the birds, so I went the elevated baseboard route.
While not through the garden it does gives me a chance to walk around the garden and I did plant out underneath with flowering plants to give some colour.
Doing this also allowed me to call on my old HO skills to create believable scenes on the baseboard which do not require weeding.
https://ringbalin-light-railway.blogspo ... -2023.html
The baseboard frames https://ringbalin-light-railway.blogspo ... ework.html
To keep everything low maintenance I use artificial turf for my pathways, only had to crawl around once. https://ringbalin-light-railway.blogspo ... ayout.html
Bit of scenery https://ringbalin-light-railway.blogspo ... cross.html
I started min in 2019 and have not regretted my decision to go elevated one bit especially after open heart surgery.
Post by Phil.P » Wed Apr 08, 2026 12:46 pm
Some better weather, so a couple of photos, and more musing:
Side of bungalow
Side of bungalow
The choice is to either come off the patio (next post/photo) at roughly the level the existing track is, or at the height of the top of the first brick under the rendering. - This would probably make the end of the line being adjacent to the edge of the present patio.
Post by Phil.P » Wed Apr 08, 2026 12:49 pm
View from the patio:
View from patio
View from patio
This shows the line would be 'three bricks' above the patio, 4-5 bricks above the grass. - About 3-bricks,by the time you get to the path running down the side of the garden..
Post by philipy » Wed Apr 08, 2026 3:23 pm
FWIW, in my case that would be the worst of all worlds, too high to kneel and too low to bend! Of course, it really depends on your personal flexibility, but 10 years ago when I was your age, it didn't pose me any problems and I wasn't expecting that it would. How wrong can I be?? :roll:
Tingewickmax
Post by Tingewickmax » Fri Apr 10, 2026 10:06 am
Is this what you are looking for Phil ? Well, I tried raising the front of the garden 10 years ago. The only problem is 10 years later the back of the garden is proving difficult to manage. So long as the trains don't derail not a problem as they can be set up out front. Or even from a sneaky siding that goes indoors, 30" above floor level. Max.
Post by ge_rik » Fri Apr 10, 2026 2:24 pm
You've seen my railway, Phil, so you know how it's laid out, varying from around 18" to 6" above ground level
Johnnie1000
Post by Johnnie1000 » Fri Apr 10, 2026 3:30 pm
Sixty eight? I'm not far behind you. You could do what I did and raise the whole thing 700mm using a lot of wood and some filcris. It runs through the shed too so I can run in filthy weather or just shunt the yard in there. There's no way I could scrabble round on the floor for the hours I used to. YouTube channel for reference. It's never going to be a bucholic narrow gauge railway, but it does me.
GAP
Post by GAP » Fri Apr 10, 2026 10:22 pm
Johnnie1000 wrote: Fri Apr 10, 2026 3:30 pm Sixty eight? I'm not far behind you. You could do what I did and raise the whole thing 700mm using a lot of wood and some filcris. It runs through the shed too so I can run in filthy weather or just shunt the yard in there. There's no way I could scrabble round on the floor for the hours I used to. YouTube channel for reference. It's never going to be a bucholic narrow gauge railway, but it does me.
Agree with this.
Try at 71 once you turn 70 they move the floor further away from you or your arms shorten.
I built mine with this in mind when I moved the old one was down on the ground but at retirement it was getting harder to reach add in a ladder accident and 2 hip replacements because of it sort of forced an elevated line.
Shunting yard in a shed is the bees knees
