Narrow gauge coach formation
HarryW
Post by HarryW » Mon Feb 24, 2025 10:51 am
I am currently working on designing and producing a set of coaches for a 45mm 16mm scale garden railway.
For a rake of British narrow gauge coaches, what is a standard formation of coaches. I gather the compartments you can do are First, Second, Third, Luggage, Guard. Which of these are essential for a plausible rake of coaches? Do you need a guard compartment at both ends? Are duckets a necessity? I've also seen the label for a 'Brake' compartment. Is this the same as a guard compartment?
My plan is for a first class coach (possibly with a luggage compartment), a second class coach, and a third class coach with a guard compartment at the end. Is this a prototypical formation?
Sorry for the amount of questions.
Harry
Re: Narrow gauge coach formation
Post by philipy » Mon Feb 24, 2025 11:20 am
Not sure that there really is any such thing as a standard or typical formation. Then again "narrow gauge" is a very wide field. The Lynton & Barnstaple was much more of a 'mainline' operation than, say, the Festiniog & Blaenau. The F & B ran a Brake/3rd, 1st/2nd Composite, 2x All Third - all 4-wheelers, standard formation, mainly because that is all they had! The L & B in contrast had bogie stock, of which there were 16 or 17 of 6 different types.
So in answer to your question, you can run whatever you fancy! Generally speaking, on narrow gauge lines 1st class would have been very limited ( on the F & B it was a single 1st class compartment sandwiched by a 2nd class at both ends) and the majority would have been 3rd class. A full brake ( guards) was rare and most would have been an enlarged compartment at one end of a passengar coach ( Brake Composite).
HarryW
Post by HarryW » Mon Feb 24, 2025 12:08 pm
Thanks for the information. In that case I may do a brake/3rd, first and second composite, and maybe an all third.
Post by ge_rik » Mon Feb 24, 2025 12:36 pm
As Philip says, it was dependent on each railway's resources.
For example, the Southwold Railway had six (six wheeled) coaches - three were first/third composites and three were all thirds. The only difference between the seats in first and third was cushions on the wooden bench seats.
The Welshpool & Llanfair had the three bogie coaches - two were 3rd/brake/1st composites and one was all 3rd.
The Leek and Manifold had four bogie coaches - two were brake/third/ first and two were third only
The Rye & Camber had two bogie carriages - one was 1st/2nd composite and one was all 3rd
The Schull & Skibbereen had eight coaches (five four wheelers and three bogies) - one of the four wheelers was All 1st and the other four were all 3rds. One bogie coach was a 1st/3rd composite and the other two were all 3rds
As Philip says some railways (eg IoM) had dozens of coaches
Hope that helps
HarryW
Post by HarryW » Mon Feb 24, 2025 1:28 pm
Thanks for the further info. It seems second class compartments are less common than I had thought. I may go for a Brake/third/first and an all third like the Welshpool ones (which I've also just looked at and realised they don't have duckets on their guard compartment).
