16mm Scale O&K MD1
- 90733
16mm Scale O&K MD1
A number of years ago I started scratchbuilding an O&K MD1 following the Saltford Models plans. It's a tiny little thing so I was never going to motorise this iteration, but it's been sat waiting for a free rolling chasis for years now... I got a 3D printed last year, so 10 minutes on TinkerCad and 20 minutes of printing now means it's finished
It's free rolling so I'll use it for either double heading or top and tailing trains at the moment, but I do have plans for a small motorised wagon at some point.
Thanks
Jack
Jack
Re: 16mm Scale O&K MD1
That looks nice Jack.
Obviously it is small but I'd have though you could squeeze something like an N20 gearmotor in there?
- GTB
Neat work on the model.
Powering these little takkers is always a challenge. An N20 gearmotor was also my thought.
Space for batteries is the bigger problem and might require a battery wagon. However an RCR123A rechargeable 3.7V Li cell is only 34mm long x 16mm dia. and you might be able to squeeze in a Micron Mr601a Rx as well.
hoppy504
Would it be possible to insert a battery into the drivers body from the bottom ?
That's exactly what I had to do with my 'Spooner's Boat' model. The seated driver was drilled from the bottom to hold an AAA battery with a brass strip alongside it, this becomes the full circuit when the head is attached with a brass tube around his neck acting as a switch...hoppy504 wrote: Sun Feb 02, 2025 1:29 pm Would it be possible to insert a battery into the drivers body from the bottom ?
Unfortunately not powerful enough to include RC.
- Lonsdaler
Ingenious!Peter Butler wrote: Sun Feb 02, 2025 2:44 pmThat's exactly what I had to do with my 'Spooner's Boat' model. The seated driver was drilled from the bottom to hold an AAA battery with a brass strip alongside it, this becomes the full circuit when the head is attached with a brass tube around his neck acting as a switch.hoppy504 wrote: Sun Feb 02, 2025 1:29 pm Would it be possible to insert a battery into the drivers body from the bottom ?
- 90733
Thanks everyone!
In this day and age it’s probably very easy to motorise, but this one has a solid floor with lots of weights glued inside the bonnet, so drilling it all out later in the build would have been a absolute faff! Getting a battery in a figure is some going, impressive stuff.
Thanks
Jack
Jack
