Maxwell Hemmings OGWEN loco
pjb
New User
New User
Post by pjb » Thu Sep 26, 2024 4:11 pm
Hi
Is there any member who could advise me how to gain access to the gas jet on the locos burner, I have removed the gas tank with pipe and burner assemble, the jet is blocked but the burner assemble appears to be glued to the brass fitting which the pipe is soldered and which the gas jet is attached, with the burner around it, making access impossible
Re: Maxwell Hemmings OGWEN loco
Post by philipy » Thu Sep 26, 2024 5:25 pm
Hi Peter,
Welcome to the forum.
Sorry I can't help with your query, but just to let you know that I've moved this post from the How To section to this Technical Help where you are more likely to get an answer. The How To.. section is more for assistance with this forum itself.
