Weed slashing train
Weed slashing train
Greg alerted me to this ..... Clever idea
I was wondering, though, if the horizontal strimmer should precede the vertical strimmer - to clear the track of debris. Maybe he tried that and it didn't work so well
Re: Weed slashing train
That is brilliant, absolutely phenominal!
Wonder how it would do with my overgrown lonicera and heathers?
Rik, I'd have thought that a third vehicle with a blower, possibly behind the loco, would do a better job of clearing debris?
- Ianm
I saw this on Youtube a week or so ago. I was so inspired that I have ordered a shaft, bevel gears, and bearings to put one together. Still wondering whether to make up a frame in mecanno or sheet metal. Probably go with mecanno for a prototype.
I have a 24v scooter motor to try with it, hoping it won't hurl the beast off the rails when it starts using a lawn strimmer battery.
If it gets built I'll post some pictures and perhaps a video - possibly of its self destruction
Ian M
WIRL
WIRL
I bought a cheap 18v battery strimmer on ebay last year for around Β£30. It works surprisingly well. I notice there are some cheaper (3.7v) ones now available which could maybe form the basis for one of these - https://www.ebay.co.uk/itm/315478015216
I may or may not have a dismantled battery whipper-snipper (strimmer) waiting in my cupboard for the past three years.
- Melbournesparks
This was the most reliable configuration, the vertical cutter chops off the fern fronds and stuff that overhang the track then they get mulched.ge_rik wrote: Thu Jun 27, 2024 2:33 pm Greg alerted me to this ..... Clever idea
This has been a common suggestion, but the short answer is that it doesn't actually work that well, and also just isn't needed.philipy wrote: Thu Jun 27, 2024 3:47 pm That is brilliant, absolutely phenominal!
What is missing here that's normally part of the maintenance train is the tank wagon with soapy water in it to wash all the plant juice off the rails.
Melbournesparks wrote: Sat Jun 29, 2024 2:27 pmThis was the most reliable configuration, the vertical cutter chops off the fern fronds and stuff that overhang the track then they get mulched.ge_rik wrote: Thu Jun 27, 2024 2:33 pm I was wondering, though, if the horizontal strimmer should precede the vertical strimmer - to clear the track of debris.
- Ianm
I couldn't resist a WIRL version of Melbournesparks weed slasher. So a few bits from evil bay and similar, a dig in the bits box, and a few hours (8 hours or so) with the 3D printer, an hour or three on the Myford, and the WIRL PWD monster is born. The video should be live about 20:15 this evening showing the first run of the prototype.
https://youtu.be/V00dOf-uybo
Some work still to do to pretty it up, but it coped with the yellow something that covers the track at the start of the incline curve, and also sorted out a bit of overhanging Box hedge at the fire pit curve.
Ian M
WIRL
WIRL
Looks promising. I see Melbourne Sparks put a cover over his, presumably to protect the mechanism from the debris. If it was extended backwards, it could maybe also protect the loco... ??
I think that is just a brilliant machine for clearing weeds and overhangs from flowers and the like.ge_rik wrote: Thu Jun 27, 2024 2:33 pm Greg alerted me to this ..... Clever idea
Would save Anne a load of weekly work in the growing season..
- Melbournesparks
That's way better engineered than mine! Using proper gears and bearings is definitely the way to go, my 3D printed gears are visibly worn after only about three trips over the line. Using the whipper snipper line instead of the metal blades is something I've been meaning to implement as well, less likely to break the gears if you hit something solid like a big stick.Ianm wrote: Tue Jul 09, 2024 7:48 pm I couldn't resist a WIRL version of Melbournesparks weed slasher. So a few bits from evil bay and similar, a dig in the bits box, and a few hours (8 hours or so) with the 3D printer, an hour or three on the Myford, and the WIRL PWD monster is born. The video should be live about 20:15 this evening showing the first run of the prototype.
Some work still to do to pretty it up, but it coped with the yellow something that covers the track at the start of the incline curve, and also sorted out a bit of overhanging Box hedge at the fire pit curve.![]()
Probably a good idea, the wet plant juice is difficult to clean. The long term plan is to build a dedicated self powered unit that does all the weed clearing jobs and is built for the purpose and easy cleaning in mind.ge_rik wrote: Wed Jul 10, 2024 8:28 am Looks promising. I see Melbourne Sparks put a cover over his, presumably to protect the mechanism from the debris. If it was extended backwards, it could maybe also protect the loco... ??
- Ianm
Thanks for the comment - I am flattered that you approve the engineering
The bevel gears were a revelation - Β£10 for the pair - they are much better engineered than I expected at that price. And the pair of bearing blocks (Β£16 for the pair) and 8mm silver steel axle all ordered and delivered in less than a week.
Looking at the 3d printing, the design took a couple of hours in Sketch-up for the motor and bearing mounting block took about 12 hours and the battery holder another 3 hours - but fairly painless.
Currently working on a skirt to keep the trash off the wheels (a bit) and then to make a cover. Updates to follow.
I donβt think I will need the horizontal slasher as the track is mostly on a filcris ladder with roofing felt so, hopefully the vegetation will not grow through it. I am leaning towards a rail mounted fan and ducting to clear debris in the non too distant future.
Ian M
WIRL
WIRL
All looking very impressive Ian, I'm watching with interest. Do you think your strimmer filament cutters would cope with heather? I have it along several feet of my track where it isn't very easy to get to.
- Ianm
Hi Philip
I think the strimmer cord would cope (short of woody stems) but not sure the slasher would stay on the track if the load was unbalanced left to right. I trimmed round my track with a normal strimmer a few weeks ago and plan to use the WIRL Monster each week to keep the vegetation back (including the winter months as the For-get-me-nots and primroses grow and completely cover the PW
Further trial updates to follow - rainy days permitting
Ian M
WIRL
WIRL
- Ianm
Hi all
I posted a follow-up video showing the updated weed slasher, responding to Rikβs comments about adding a cover to the motor and gear train. I actually made the cover etc. shortly after Rikβs and other comments on the beast, but then failed to make a video to show it off. I have used the slasher fairly regularly over the winter and particularly in the last month as the primroses etc have begun to encroach on the track. As you may be able to see in the video ([url] [url]) the slasher hurls primrose flowers to the wind - fortunately SWMBO was out and missed the show. Currently it takes about 10 minutes to trim the track edges about once every 7-10 days. Nw I need to get back to making a mower to tidy up the low growth and also a sweeper to remove debris from between the tracks.
The cover is made from a plastic container that the car windscreen wash came in. Its sprayed with rattle can and then the bumble bee strips using masking tape and over spraying. Itβs standing up to the use quite well, which is satisfying as painting is not a favourite pass-time. I added a Micron RX to control the motor, which makes using the beast a little more user friendly and also means the cutter can be stopped when passing buildings etc. that are a bit close to the whirling dervish - donβt ask how I know that is a problem
Hope you like the evolution so far.
Ian M
WIRL
WIRL
Like this a lot
