Cabbed Hunslet
- -steves-
Cabbed Hunslet
Thought I would do a cabbed Hunslet type loco, but for 32mm this time, unlike Stephen which was 45mm. Not built it or even printed it all yet, but it's getting there.
Re: Cabbed Hunslet
Ooh, that's looking a bit tasty.
You planning on resin or filament or a mixure of both?
- -steves-
Re: Cabbed Hunslet
At the moment filament, but I think one or two bits will end up being resin, namely the water filler cap as it does not print well in filament. The rest is doing quite well. I had a motor in a chassis with just the back 2 wheels in and it runs well enough. Bit of a tight fit between the wheels, chassis and motor mount. To be fair, I might end up making the wheels on the lathe as they will be truer and there just isn't any room for even a minor wobble. For me the wheels are a day in the shed on the lathe, a bit on the cool side for that right nowphilipy wrote: Sat Feb 24, 2024 12:40 pm Ooh, that's looking a bit tasty.![]()
Re: Cabbed Hunslet
Very tasty! Almost worth changing to 32mm gauge .....
Re: Cabbed Hunslet
A call from the Dark Side..... first Aaron, now Rik.
That would be like rewriting history!
- -steves-
Re: Cabbed Hunslet
Well not much to report, but I have started the initial build of this, it's going together reasonably well so far. I have done two chassis as a friend wanted one as well. Obviously loads left to do, but making progress.
Re: Cabbed Hunslet
Steve, you're either an untidy worker or proud to show off your wonderful collection of screws and bearings. A most impressive assortment!
- -steves-
Re: Cabbed Hunslet
Unfortunately I am a seriously untidy worker, I like everything to hand. The really surprising thing is, I actually tidied it up a lot before taking the pictures, lolPeter Butler wrote: Sun Mar 10, 2024 4:44 pm Steve, you're either an untidy worker or proud to show off your wonderful collection of screws and bearings. A most impressive assortment!
- -steves-
Re: Cabbed Hunslet
Not sure about the finish yet. I think some will end up papered and some won't, depending how hard it is to get a good surface with sanding alone. I will probably do one in black, if I build another, not sure of the colour.
Sam95
Re: Cabbed Hunslet
That's looking great.
One of my next project is to print a loco. I am equipped with LGB track so I think it is 45mm ?
Do you have a link to the model you have done for 45mm ?
I don't want to design my first loco. I prefer tu print an already approved one.
Thanks
Sam
Thanks
Sam
You can visit my blog
http://sam95.fr/
http://sam95.fr/
- -steves-
Re: Cabbed Hunslet
I did this one a while back in both 32mm and 45mm. Lovely little Bagnall.Sam95 wrote: Mon Mar 11, 2024 9:06 pm That's looking great.
Thanks
Sam
https://www.thingiverse.com/thing:6361409
Sam95
- -steves-
Re: Cabbed Hunslet
Not much on this for a while, mojo isn't all that high at the moment. I have not rivited it, added detail, nor weathered it, not even added buffers, but it is as it is and makes a nice base for a loco. Other than adding buffers, that's probably as far as I will go on this for now. Sorry it isn't to my usual standards but a lot has been going on. I apologise for the shite paint job too, looks worse in the pictures that in does in real life that is for sure.
So here it is. Lots of stones and moss on the test track so it's a bit bumpy
I will happily add the 3D print files if anyone wants a 32mm gauge cabbed Hunslet?
Re: Cabbed Hunslet
I'd quite like to add it to my to do list, please Steve. Not sure when it will get past being on the list, I'm already in serious bovver over the amount of time I've put in on the Gmeinder!-steves- wrote: Tue Apr 02, 2024 12:59 pm
- drewzero1
Re: Cabbed Hunslet
I'm absolutely interested, though also on a long timescale. (Maybe a next winter project
) I think it would fit very well on my line... my little Thornas was originally meant to be a Hunslet before I got seriously distracted!
Re: Cabbed Hunslet
Paint job looks fine to me, Steve. I'm never sure about having a high gloss finish on ng locos. I tend to dull mine down with a coat of satin lacquer anyway.
- tommygander1941
Re: Cabbed Hunslet
Been a while since anyone posted on this.
I'd be interested in at least the chimney, as its probably the most accurate for a 16mm scale Quarry Hunslet (PDF and BLW both seem to follow these 5" gauge drawings
- Attachments
- Screenshot 2024-09-09 23.54.28.png (178.18 KiB) Viewed 140198 times
