Outside framed motor blocks for 45mm gauge
Post by ge_rik » Fri Dec 15, 2023 7:29 pm
In addition to the .stl files you will need:
For the V1 motor block:
  • 4 x M3 square s/s washers (from eBay)
  • 4 x 6mm M3 s/s grub-screws (from eBay)
  • 2 x 4mm dia s/s shafts (from MFA Como
  • 2 x 4mm bore bevel gears (from MFA Como)
  • 1 v 918D301/1 gearbox motor (from MFA Como)
  • 4 x 4mm brass bearings (from Essel Engineering - email and ask for a special order)
  • 2 x 4mm bore 16 tooth timing belt pulley (from eBay)
  • 1 x T2.5-180-10 10mm wide 180 length looped timing pulley (from eBay)
Optional
  • 4 x 30mm dia wheels with 4mm bore (from Essel Engineering - email and ask for a special order
Motor block v1.zip
(103.39 KiB) Downloaded 767 times
(NOTE: If you don't want to use the timing belt, then you could use the fly-cranks and coupling rods from the V2 motor block)
For the V2 motor block:
  • 8 x M3 square s/s washers (from eBay)
  • 8 x 6mm M3 s/s grub-screws (from eBay)
  • 2 x 6mm bore bevel gears (from Amazon)
  • 1 v 919D301LN gearbox motor (from MFA Como)
Optional
Motor block v2.zip
(301.45 KiB) Downloaded 761 times
(NOTE: I used a 50:1 gearbox motor but it was too slow - 30:1 is better)
- Rik Bennett, licensed under CC-BY-NC-SA 4.0
CC - Creative Commons
BY - Attribution, i.e. you must identify me as the author of the work if you share it
NC - Non-commercial, i.e. you cannot sell it or make profit from it
SA - Share-alike, i.e. you are allowed to create derivative works (let's say you improve the STL file by adding some rivets) as long as you share it under the same licence.
Re: Outside framed motor blocks for 45mm gauge
Post by ge_rik » Fri Dec 15, 2023 7:57 pm
Here's examples of the additional items I got from eBay
Here are the 6mm bore bevel gears from Aamazon
Post by ge_rik » Fri Dec 15, 2023 7:59 pm
Here are the additional items from MFA Como
Post by ge_rik » Fri Dec 15, 2023 8:00 pm
And here are the bushes from Essel (make sure you ask for 4mm bore - they are not listed but Stephen will make them as a special order)
Post by ge_rik » Fri Dec 15, 2023 8:10 pm
And here's the timing belt and pulleys from eBay
timing belt.jpg (218.8 KiB) Viewed 30155 times
timing pulley.jpg (292.98 KiB) Viewed 30155 times
Post by -steves- » Sat Dec 16, 2023 4:45 pm
Very useful post Rik, many thanks :thumbup:
