Next overhaul project....
Scrat
Post by Scrat » Sat Dec 02, 2023 9:09 pm
Postman brought a big box (not quite that big...) yesterday:
My next 5" gauge winter project will be:
Guess please, first hint:
BTW Where can I get a replacement horse? This one is missing its tail.
I have seen many things on the wrecks that come in for overhaul, but I have never before seen a blower valve handwheel made from a new penny.
What do you think was in the box?
Re: Next overhaul project....
Post by philipy » Sat Dec 02, 2023 9:11 pm
An Aveling model of some sort?
Post by Old Man Aaron » Sun Dec 03, 2023 6:27 am
Judging by the not-black smokebox door, maybe something pre-Victorian?
Far as bodges go, that penny doesn't seem half terrible..
Looking forward to seeing what's next. :D
Scrat
Post by Scrat » Sun Dec 03, 2023 12:53 pm
philipy wrote: Sat Dec 02, 2023 9:11 pm An Aveling model of some sort?
You are pointing in the right direction.
Next hint:
No steam roller, no traction engine.
Post by philipy » Sun Dec 03, 2023 1:14 pm
Presumably the Aveling Porter from the Brill/ Wooton Tramway
Scrat
Post by Scrat » Sun Dec 03, 2023 3:11 pm
philipy wrote: Sun Dec 03, 2023 1:14 pm Presumably the Aveling Porter from the Brill/ Wooton Tramway
We have a winner.
Part-finished 5" model. I just removed a broken bolt from the cylinder block.
She still needs quite a bit of work.
Pics to follow.
Post by Phil.P » Mon Dec 04, 2023 11:53 am
Go on then...
Post us a picture!
:thumbright:
Scrat
Post by Scrat » Mon Dec 04, 2023 12:34 pm
She´s in bits now, so this is the only picture I can show:
Had to get a broken screw out of the regulator assembly (fortunately the remaninig bit was long enough).
Removed some play and clatter from the motion, modified the buffer beams, fixed many small issues.
But a long list of small jobs is still there.
Most parts are now primed and ready for painting.
I still need to make a firehole door and the matching hinges, fit whistle valve and whistle and fit some lead underneath to improve traction.
The brake gear is really simple on the prototype so it will be quite easy to make.
Then I will have a test run. If that works, I can start on the many details.
Post by -steves- » Mon Dec 04, 2023 12:53 pm
that looks really nice, wish I had one :mrgreen: Looking forward to seeing it all put back together and of course, running. :D
Post by Phil.P » Mon Dec 04, 2023 5:36 pm
Thank you..
Nearly done then? - Two weekends work, as they say.
:lol:
Post by Old Man Aaron » Tue Dec 05, 2023 5:21 am
Never would've imagined a traction engine, you don't see many around. That'll be a really interesting project.
Post by philipy » Tue Dec 05, 2023 6:13 am
Old Man Aaron wrote: Tue Dec 05, 2023 5:21 am Never would've imagined a traction engine, you don't see many around. That'll be a really interesting project.
Aaron, no, its a railway loco not a traction engine, although the original was built by a traction engine maker.
You must have missed the original thread, which did wander a bit. :D
viewtopic.php?f=29&t=14528&p=176056#p176056
dudeface
Post by dudeface » Tue Dec 05, 2023 3:43 pm
philipy wrote: Tue Dec 05, 2023 6:13 am It's a railway loco not a traction engine, although the original was built by a traction engine maker.
Well technically I think it's a rail traction engine. I'm pretty sure that's what Aaron meant.
Big Maple & Little Oak RR
Post by Old Man Aaron » Wed Dec 06, 2023 3:49 am
philipy wrote: Tue Dec 05, 2023 6:13 am You must have missed the original thread, which did wander a bit. :D
Oh, now I remember - colander brain strikes again. :lol:
dudeface wrote: Tue Dec 05, 2023 3:43 pm Well technically I think it's a rail traction engine. I'm pretty sure that's what Aaron meant.
That's what I was getting at. ;)
Scrat
Post by Scrat » Wed Dec 06, 2023 7:42 am
some progress:
first coat of Vermillion on the buffer beams, first coat of mid Brunswick green on the wheels and some minor parts.
Paint is good quality but takes a long time to dry.
Next steps will be painting other parts and making a firehole door.
I have a whistle and matching valve but no idea yet where to put them without spoiling the overall look of the engine.
Keith S
Post by Keith S » Thu Dec 07, 2023 12:08 am
Aren’t all railway locomotives “traction engines” if one is being really, really annoyingly technical and pedantic?
dudeface
Post by dudeface » Thu Dec 07, 2023 12:50 am
Keith S wrote: Thu Dec 07, 2023 12:08 am Aren’t all railway locomotives “traction engines” if one is being really, really annoyingly technical and pedantic?
Yes.
Scrat
Post by Scrat » Wed Dec 13, 2023 8:28 am
Started running on air last weekend.
Smokebox horse has received a replacement tail.
Found suitable mounting positions for whistle and valve.
Firehole door still to be made.
Maybe she will run under her own steam still this year.
dudeface
Post by dudeface » Wed Dec 13, 2023 3:08 pm
Yay! :blob6:
Scrat
Post by Scrat » Fri Dec 22, 2023 4:02 pm
Finally got around to make the firehole door.
As there is almost no space around it this was a bit tricky.
Clearances to any boiler fitting are 1mm.
Now I am waiting fo the storm to go somewhere else so I can test the loco.
