A couple of days ago whilst looking for some info, I came across a reference to a Youtube blogger that I hadn't seen before. He seems to specialise in Enders and Cura, but one of the things he does is tweak Cura to get the best surface results without ironing etc. I gave it a try yesterday and first attempts blew me away, as they say!
I recently had to print a box for somebody with incised lettering on the lid between 5 and 8mm high and try as I might, I couldn't get it to print cleanly with a good enough smooth surrounding surface - subsequent sanding etc wasn't an option on this project. (I eventually did it by printing upside down with the 'finished' face on the glass bed ).
However I've just printed a part of the lid the right way up, using this guy's Cura 5.0 settings on my Cura 5.2.2 and it is perfect, no stringing and virtually no marks on the almost mirror top surface. It's very difficult to photograph to show nothing, but hopefully you'll be able to see the quality. The faint diagonal lines which you can just see on the picture are actually not visible to my naked eye. The letters are 6mm high, btw.
His blog with this profile in (There are several different profiles but I've used the "Good" one here) is at:
https://www.youtube.com/watch?v=jM_jdsx5yFc
If you scroll down his video's list, further down is a similar post re Cura 4.9 ( https://www.youtube.com/watch?v=jkAqTWmVRVA) in which he shows the rationale behind how he gets these results. His complete set of video's are:
https://www.youtube.com/@FilamentFriday/videos
Excellent Cura profiles and other useful stuff
Re: Excellent Cura profiles and other useful stuff
That does indeed look good without ironing. I might try analysing his settings to see if there's anything I can tweak with mine
- GAP
CHEP has been my "go to guy" ever since I started down the dark path of 3D printing.philipy wrote: Sun Feb 19, 2023 7:52 am A couple of days ago whilst looking for some info, I came across a reference to a Youtube blogger that I hadn't seen before. He seems to specialise in Enders and Cura, but one of the things he does is tweak Cura to get the best surface results without ironing etc. I gave it a try yesterday and first attempts blew me away, as they say!
The other is Brian Vines (3DBV)
