First Ever Garden Railway
Re: First Ever Garden Railway
There may be space for the track to remain level and deviate around the steps in a cutting, or even a tunnel if the top step is raised?
Would need to be a tunnel under the top step- but that's very deep. I'm going to proceed with the bridgePeter Butler wrote: ↑Wed Feb 22, 2023 1:17 pm There may be space for the track to remain level and deviate around the steps in a cutting, or even a tunnel if the top step is raised?
Nicholas J
Thanks for the responses everyone, and for the useful links, Graeme- much obliged.
I'll go with the bridge idea. That seems the most straightforward- literally.
Nicholas J
Sounds like a plan!
You can always start simple, with a plank braced with 2x1, and then create something more elaborate later, when you've got things up and running...
You won't go wrong with these guys advising ya! Looking forward to seeing your line unfold.
Last qu for a bit ... hopefully... the track bed will be ballast - the track won't be fastened down except on the bridge.
For the 'dogbone' loop - per the diagram, would you suggest going with flexible track and bending it to shape, or pre-made curved sections for at least some of it?
I do want it to be quite tight - to save space, but apprehensive - if I bend, presumably it stays bent without needing to be fixed down?
Cheers everyone!
Cheers everyone!
Nicholas J
Update: we have track!
Most of the straights anyway. I need a lot of set-track curves and points… 6 in total.
Coming from the 00 world…. I can’t believe the cost of points. It’s looking like £450 just in those?
If anyone has any they’d like to offload I’d certainly appreciate being able to shave the cost a bit!
- Attachments
- 8B282E5A-9681-4B7E-87E9-0809F443AE94.jpeg (6.98 MiB) Viewed 3440 times
Nicholas J
- GAP
How adept are you at cutting/grinding/soldering brass.ashover wrote: ↑Fri Apr 07, 2023 10:01 am Update: we have track!
If it's no problem then I have some plans to make your own points.
I do not use set track I use flexible track because it allows me to make curves of any size radius.
Thanks Graeme - I’d certainly be open to learning. I do have a soldering iron at least!
Nicholas J
Agree with Graeme on both counts, plus its cheaper to buy flexitrack than set track and cheaper ( and more satisfying) to build your own pointwork.
Building points is nowhere near as difficult as some folks make it out to be, just get some track gauges and go steady and don't expect to do it in a couple of hours.
I’d enjoy it I think. Sounds very satisfying!
Does anyone have a good guide I could look over?
Issue with not using set track is I’m confined on space for the loops - and I didn’t want to risk messing up my first ever layout by getting the bends wrong!
Silly question but once the tracks are bent, they do stay bent? My track will be floating on ballast, you see.
Nicholas J
"Silly question but once the tracks are bent, they do stay bent? My track will be floating on ballast, you see" .
They do if you use a rail-bender, and cut some of the webs between the sleepers.
I also find it 'better' to slightly over-bend the track, as it seems to 'relax', a little, back towards being straight.
My biggest problem, is seeming to get twist into the curves. - This lifts the outer rail (mostly) and we really do not want this. Track should be level across the formation.
- GAP
The plans are in pdf format and print out on A4 paper which is taped together to get a template of the rails and the sleepers.
I sticky tape it onto a piece of ply and build directly over the template then tear the paper when finished.
I'll just need an email address to send them to.
Bear in mind that they are large (No5 in US speak)
Much appreciated - thanks Graeme. I sent you a private message.
Nicholas J
Been a little slow lately but hoping to get the groundwork done in the next couple of weeks.
I thought looking for locos might motivate me- especially if I buy one and see it sat there!
The plan is to get an electric (diesel) logo as a kind of test-loco before investing in live steam.
OR, I considered getting a Mamod/MSS as the test loco.
Just a few questions:
Is the Mamod/MSS a bit unruly? I wanted a slow runner - whereas they look a bit wild?!
I'm assuming a more expensive Roundhouse or Accucraft loco is easier to run slower, and longer? I don't know much about them, but assume that they reach higher temps/pressures due to gas firing and possibly they're just more sophisticated?
Many thanks!
Many thanks!
Nicholas J
Aye, a battery loco would be much better than a Mamod/MSS. They're very much a tinkerer's loco, and take a lot of work to make them run properly.
Yes, I agree with Aaron, get a battery electric loco for starters/track testing - diesel/electric/steam outline makes no real difference, it's down to your own preferences. Mamod/MSS are relatively cheap but notoriously difficult to get to run well and are a hobby in themselves.
I'm all for battery power. As folk will know, I'm not a great fan of live steam. I have nothing against live steam as a concept but the way I run my railway demands slow running and a high level of controllability. For me, locos are the means to an end and not an end in themselves. So, a lot depends on how you want to run your railway.
My thoughts ( but others will have differing views):
Live Steam Locos
Live Steam Locos
- Like the real thing
- Satisfying to run
- Quite expensive
- Takes a while to learn how to control them
- Relatively short run time between refuelling
- Easy to run (switch on and go)
- One charge lasts for hours of run time
- Relatively cheap to get started
- Good for slow running and fine control
- You can easily make your own from kits or scratch
- Less realistic
- Some say they are less satisfying (but I don't)
Thanks everyone!
Gosh, you’re not wrong about Mamods being a hobby in of themselves! I think the loco would occupy far more time than the railway!
I’ll pick up a diesel for now from somewhere.
And regarding slow running with live steam - that’s achievable with Roundhouse, etc? It seems to be.
Whenever I Google things to do with live steam and slow running I run into Mamod/MSS owners trying to slow theirs down
Nicholas J
I'm probably not the best qualified to answer this question but from what I've seen and heard, the most reliable way to achieve controllability and slow running with a live steam loco is to install a Slomo device, which is, in two effect, a geared flywheel. There are a few impressive YouTube videos around showing Slomo equipped locos in action. Unfortunately, Terry has now ceased production of these devices so you might have to see if you can pick up a secondhand loco with one fitted.
Failing that, Zach on this forum has produced a Momentum Van based on a kids' toy which has the same effect. https://gardenrails.org/forum/viewtopic.php?f=39&t=9667 I can testify as to its effectiveness as he has run a couple of his locos on my railway with the van in tow.
Alternatively, I have seen first hand some really impressive slow running of unmodified live steam locos by accomplished operators. It does take a fair bit of experience to get all the variables perfected but I can see how it would generate a great sense of achievement to be able to control a live steam loco in such a way. From what I understand, some live steam locos are easier to control than others. I believe some Accucraft locos have a good reputation - but others with more knowledge can probably advise with specific examples of the most controllable out of the box live steamers.
