Bearings
Do you want a specific item?
PLEASE NOTE: We accept no responsibility for loss of property or money
Bearings
Post by FWLR » Sat Sep 17, 2022 1:43 pm
Can anyone help me with finding where I can buy these from please. I print my own chassis, but I need the top hat bearings for them.
They are the standard size 3mm o/d.
Thanks guys.
Re: Bearings
Post by philipy » Sat Sep 17, 2022 2:40 pm
I've been using these. They come in a packet of 8 and they are cheaper than any I've found advertised for railways - these are intended for road vehicles but are 3mm bore which is the important bit. They are slightly longer but that's easily trimmed off if you need to.
https://www.ebay.co.u/itm/114313789511
Full length on the left, and trimmed on the driven axle
Re: Bearings
Post by ge_rik » Sat Sep 17, 2022 4:21 pm
I got some from Essel Engineering.
I wanted 4mm bore which aren't listed on his website but he said that as he makes them himself he can make them to any size.
Re: Bearings
Post by FWLR » Sun Sep 18, 2022 8:40 am
Thanks Phillip and Rik. :thankyouyellow That is brilliant info.
Never lets me down this forum. Someone will always come up with a brilliant answer. :salute:
Re: Bearings
Post by philipy » Sun Sep 18, 2022 9:44 am
Rod, I've just looked again at the photo in your original post and realised that you are showing an outside diameter on the bearing of 2.99mm, which presumably means you want a 2mm bore, not 3mm? In which case of course, my suggestion is wrong, my apologies.
The outside diam. is only semi-relevant, it's the axle diameter/bearing bore which are important.
Re: Bearings
Post by FWLR » Sun Sep 18, 2022 12:11 pm
Thanks Phillip. Not to worry, it's an easy mistake to make. :thumbright:
I do it all the time. :lol: :lol: :lol:
