An international forum for garden railway modellers in all scales and gauges. It is free to join and is funded through voluntary contributions by its members. Many thanks to all those who keep it going.
philipy wrote: ↑Tue Jul 19, 2022 5:41 pm
Running nicely Rik. Doesn't it make a welcome change to have that much spare space inside for all the gubbins?!
Absolutely! It's cavernous by comparison to some of my other builds. It's also a lot easier to access the gubbins - the tank tops and boiler lift off as a single unit.
Just trying to decide whether to mount the coupling on the rear of the body or pivot it on the bogie/pony truck. I'll have to run it through my tightest reverse curves and watch closely what happens. I'll also have to raise the body by a few mm. An easy task, I'll just pack some plasticard spacers between the mounts on the motor block and the body.
BTW, I constructed this loco to 15mm/ft which is becoming my default scale since I started 3D printing the Southwold stock. I'm surprised how much difference a 15/16 reduction makes on the overall dimensions. I originally rescaled the GVT coaches to 16mm/ft and have now re-rescaled them to 15mm. Once I've finished constructing them, I'll take a few pictures of them side by side.
A fine looking end result there Rik. Will you be adding a sound card? It would round it off nicely. It's also surprising how effectively a skirted locomotive hides the need for running gear. A lovely looking locomotive.
Hi Phil
Yes, a MLS soundcard is on the agenda. I need to rationalise my stock to allow room for the new 3D printed wagons. I can then fund the soundcard from the sales of the old wagons.
Great outcome Rik really looks the biz! very smooth running too, what exactly is powering this beastie? I dont think you showed us what was under the skirt so to speak
Tropic Blunder wrote: ↑Sat Jul 23, 2022 2:08 am
Hi Jake
Thanks. It's in the video but I'll also post the piccie here. It's the motor block from a Bachmann streetcar.
I bought a couple secondhand from someone on this or the GSC forum who was replacing them with something of higher quality. The skirts hide a multitude of sins so I could have put more or less anything under it. I have actually put a trailing bogie under there although it's not really essential.
Once I've tidied up the files, I'll post them in the 3D printing section. I'll also post a version of the body without rivet detail to make it easier to rub down before painting
As mentioned in the loco lamp thread, I've now added lamps front and back with red/white bi-colour LEDs. I've also raised the loco by 3mm to give better clearance when running over my somewhat uneven track, buffers and couplings have been added plus a few other titivations ..... and, would you believe, I discovered I had a spare MLS soundcard and so that has been installed.
The loco is now ready for her first proper test run with stock. I've been clearing the track - just need some decent weather - we've been having a few days of rain - showers forecast for tomorrow.
SimonWood wrote: ↑Tue Jul 26, 2022 9:52 am
Superb result Rik, I really do like these locos. And the open door on the port side of the smokebox is a really nice touch.
Quite a few photos show these doors open and some have the access plates to the motion clipped open. Not sure if they ever ran with them open or if they were just opened when stationary, but I created the 3D parts so they could be opened if so desired. Mine are left closed as my motor block doesn't have any motion.
I think you can tell that she has been constructed to 15mm scale whereas the coaches are 16mm. When I've finished the last Southwold coach and/or the Glyn Valley coaches (all of which are 15mm), I'll see how she looks.
Looks like I might need to take an angle grinder to the platform at Peckforton - those skirts are quite wide.....
She looks wonderful Rik, a real triumph in appearance and running. No complaints about the steam sound with this one as it isn't possible to see whether it ties in with wheel rotation.
I have no experience of sound cards, so what Rik, have you used in this model?
It certainly sounds effective in the video, and I was impressed with one which I saw at the Tallyllyn railway some time ago. So my interest is aroused.
Peter Butler wrote: ↑Tue Jul 26, 2022 7:41 pm
That comment in particular has my attention! I suppose that means that they are normally just free running and might or might not be in time with the motion.
Is it possible to synchronise the sound with the motion? I can visualise a sensor identifying when the cylinder passes TDC - and therefor allowing the steam sound to be synchronised - but does anyone actually provide that?
Trevor Thompson wrote: ↑Wed Jul 27, 2022 2:44 pm
Hi Trevor
I mainly use MyLocoSound cards but I do have at least six maybe seven others in use. The MLS card is, to my mind, by far the most cost effective card available. The chuff rate is either determined by the voltage being applied to the motor or, as you suggest, by a "chuff cam". In its most basic form the 'cam' is precisely that ' a cam attached to one of the driving wheels to close and open a microswitch to directly synch the chuffs to the wheel rotation (usually four beats per rev). The MLS card can cope with a cam providing one, two or four 'pulses' per rev. Slightly more sophisticated' cams' use a light, IR or magnetic sensor (eg a reed switch or Hall Effect sensor).
One of my locos has a chuff cam - see
I actually prefer using the motor voltage. Although it's trickier to synch the chuffs to the speed (different loads or gradients affect the speed at which the loco moves in relation to the voltage), it's usually only noticeable when the loco is moving slowly. The advantage of using the motor voltage is that it can sense when the loco is decelerating and so go into the coasting mode (see when the loco coasts to a halt in the GVT video) and with the most recent card provide brake squeal is it comes to a halt. For some reason, these effects don't seem to work when using a cam (unless I've not set up the card with the cam trigger correctly).
Peter Lucas, the brains behind the MLS card is a member of the forum so you could always PM him if you want further info.
