Hi,
Might be found useful.
https://youtu.be/P-_TLQ3SrXI
Take care Tony.
Making Ceramic Gas Burners.
Re: Making Ceramic Gas Burners.
Thanks Tony, very informative.
Not that any extrapolation would be appropriate, but to give an indication, could you advise the surface dimensions of the ceramic and an approximation of the total boiler volume
Thanks in advance.
Tim
Thanks in advance.
Tim
- Tony Bird
Hi Tim,
The burner I know, as I have just made it is 10 x 30mm and uses a number 3 jet. The boiler is 55mm in diameter, not sure of the length, I will check and get back to you, but less than 100mm. However, any calculations will be effected by the couple of heat exchangers fitted under the boiler. See: https://youtu.be/WY8EBiPSlP0
Take care Tony.
Take care Tony.
- Tony Bird
Hi Tim,
The boiler length is 80 mm.
Take care Tony.
Take care Tony.
Thanks Tony
Always look forward to your projects
Tim
Tim
