Gauge 3 at 2.5" (22:1) was one of the first model railway standards and is the largest "scenic" ( i.e. non-passenger carrying ) gauge. It has the advantage of being large and robust enough to be truly suitable for outdoor use. It flourished in the 1930's with magnificent locos made by Bassett-Lowke rushing around the large gardens of the aristocracy and well to do and is enjoying something of a revival with modern flexible stainless steel track now available from Cliff Barker ( www.cliffbarker.me.uk ) making establishing a garden layout relatively simple.
But there is a shortage of motive power and rolling stock. Hence the development of a new powered chassis from Ince Loco Works, Wigan. This is provided fully built and ready to run for a basic price of £80 and follows on from the firm's very successful range of similar "pugs " at smaller gauges.
Pictures are attached. The chassis is engineered to a high standard using the best and strongest materials. Chassis side plates are 2mm steel with end and top plates also available if required. A standard 380 25mm motor (3-7.2 volts ) drives two ¼" steel axles running in ball races via a brass worm gear, axles coupled via a 6mm toothed rubber belt. Wheels are 40mm steel and the just over 500g weight helps to give excellent traction. The chassis is very compact, just 2" high and 3½" wide, overall length 6 inches.
The chassis is very versatile, capable of providing the underpinnings for a Gauge 3 industrial loco, 0-4-0 steam outline, two units providing plenty of power and speed for a Bo-Bo diesel or electric mainline passenger or freight outline among other applications. Bodies could be home built, kits or 3D printed.
If you are interest in acquiring a chassis ( each made to order ) please contact Phil Edwards via email at Ince Loco Works, Wigan, Lancs - incelocoworks@gmail.com.
[attachment=0]7_DSCF4314.JPG[/attachment
New Gauge 3 Powered Chassis
- Clive Aintreew
- Attachments
- 1_DSCF4317.JPG (1.46 MiB) Viewed 60141 times
- 5_DSCF4308.JPG (1.55 MiB) Viewed 60141 times
- 7_DSCF4314.JPG (1.53 MiB) Viewed 60141 times
angr607
Re: New Gauge 3 Powered Chassis
Is there a rough price for these? I've got a few ideas I could put these under.....
Jon
Jon
Current Projects:-
Rebuilding the Railway!
Current Projects:-
- Lonsdaler
"provided fully built and ready to run for a basic price of £80"angr607 wrote: Sun Mar 06, 2022 4:33 pm Is there a rough price for these? I've got a few ideas I could put these under.....
Jon
- Clive Aintreew
Here are two new photos with the optional end plates fitted. I think they cost about £10 including the fitting kit which clamps them to the chassis plate spacers.
The plates are 2mm steel the same as the side plates and Phil is also providing an optional full size top deck which I have ordered. Once fitted, I will post a photo.
Clive
Clive
- Attachments
- DSCF4321.JPG (1.43 MiB) Viewed 60056 times
- DSCF4319.JPG (1.59 MiB) Viewed 60056 times
