My new gardenrailway 16mm-SM 32
Jimmyb
Re: My new gardenrailway 16mm-SM 32
Post by Jimmyb » Thu Sep 23, 2021 3:02 pm
spaeker wrote: Thu Sep 23, 2021 11:37 am
My wish list there was a better range of RC controls for model railways . Since the application is clearly mature in model aircraft.
There are a few RC controls other than Deltang, though I use Deltang through RC Trains and Micron; just to name a few available:
  • Fosworks
  • Brian Jones
  • Revolution
  • Loco Works
I know there are others, just can't recall.
spaeker
Post by spaeker » Sat Sep 25, 2021 3:27 pm
thanks
I know deltang .. BUT never seems to be any technological advancements from anyoone
Whoever its still the same offering : Box ( tx) that sends fwd /reverse/ speed and if your lucky a whistle or two Wrapped up in small print.
a wish
provision of feedback to tx controller eg : track device at a station stop that resets tx controls to zero and train stops ..... ( and maybe whistles ..LOL)
do I dream ?
BorisSpencer
Post by BorisSpencer » Sat Sep 25, 2021 7:26 pm
Iirc there are programmable options on the Deltang such as Station Stop and Shuttle.
Post by philipy » Sat Sep 25, 2021 7:50 pm
BorisSpencer wrote: Sat Sep 25, 2021 7:26 pm Iirc there are programmable options on the Deltang such as Station Stop and Shuttle.
Yes, and Rik's Peckforton blogs cover those in precise detail.
Post by Phil.P » Sat Sep 25, 2021 9:43 pm
And there are those of us, on here, you can ask if you get stuck..
If you print out your own copy of the instructions,you can make the text as big as you like! :D
phil@rctrains.co.uk
Michael Schulz
Post by Michael Schulz » Sun Sep 26, 2021 7:53 am
Hello Spaeker,
so far I have a Reely remote control from www.conrad.de
A 4-channel transmitter and 2 matching receivers, each, one for channel 1 +2, the other for channel 3 + 4. So I can control the diesel locomotive NS2 with channel 1 + 2 and the steam locomotive HF110C with channel 3 + 4 all components for the remote control of RC ships.
I will use the new remote control from Piko in the future, it's simple and inexpensive:
Piko 35040 - G R / C transmitter and receiver for locomotives.
Regards from Berlin
Michael
Michael Schulz
Re: My new gardenrailway 16mm-SM 32,update
Post by Michael Schulz » Thu Aug 17, 2023 7:23 am
Hallo Gardenrailwayfans,
in this year 2023 i could something keep building. Here some new fotos.
I hope that i in this year can manufacture more "modules"
To work for the SM-32 Railways in the garden ist very good.
( in the winter i make gauge Zero / 7 mm)
Regards from "Klein Köris" near from Berlin( 40 km)
Michael
Post by philipy » Thu Aug 17, 2023 8:30 am
That is all looking very professional Michael.
Please keep showing us your progress.
Post by ge_rik » Thu Aug 17, 2023 8:51 am
You're making excellent use of the space. I like the way the trains run across the window so those in the house can experience the railway as well.
Post by Lonsdaler » Fri Aug 18, 2023 10:07 pm
That looks to be well thought out, and clever use of plastic rainwater pipe for the legs. I look forward to seeing how it develops.
Michael Schulz
Post by Michael Schulz » Sun Aug 20, 2023 8:17 am
Hallo,
thank you for your positive comments.Progress is slow because we are only in the garden on a few weekends.
Unfortunately, the track elements cannot remain set up all the time, but it's still a lot of fun to ride the train in the fresh air.
Greetings from near Berlin; Michael
Post by Phil.P » Sun Aug 20, 2023 10:23 am
Everything looks well engineered, and tidy. - Even though you are working.
Can you leave some of it up between sessions, or is access required at all other times?
Michael Schulz
Post by Michael Schulz » Tue Aug 22, 2023 3:56 am
Hallo Phil,
I have to dismantle the modules every time.
Setting up the train station takes about 30 minutes.I designed it so that I can attach the station to the shed, but also stand alone if I want to set it up somewhere else
The aluminum frames of the station modules come from aviary construction and were still cheap a few years ago. The green wooden panels are made of 100mm box plywood and are painted to be weatherproof
Michael
