Hello!
I am interested in purchasing the Maxitrak Alice locomotive! However, it states that the minimum curve radius is 8ft. I am only able to fit a 7ft radius in my garden. So I was wondering, could it run?
Thanks in advance for any help!
Curve Radius Help
Re: Curve Radius Help
Hello!
We do have some members who build larger-scale ride on lines on their gardens, but they tend to be ocassional visitors rather than regularly online, so it may take a while to get an expert answer!
I think I'd be inclined to ask Maxitrac directly - it's an expensive purchase, so you wouldn't want to mess it up! If it will negotiate the curve without damaging itself or the track, and assuming the issues affecting 5" gauge lines are the same as those which affect smaller scales ("ye cannae change the laws of Physics captain!"??!), I'd guess the sharper the curves you use the greater the wear and tear will be, and the lesser the load your engine will be ae to pull?
Good luck - it sounds like fun!
Like Andrew, I can't help I'm afraid but his suggestion of contacting Maxitrak sound a good un.
Welcome to the forum BTW.
Firstly, welcome to the Forum, secondly I am unable to help with your question but would just ask whether your tight space limitations have taken into account any overhang of stock and additional width of passengers? Even in SM32/45 we are often asked similar questions and the overhang issue always crops up.
